Mounts
Old Apr 16, 2013 | 04:03 PM
mis3's Avatar
2004 CLK320
Mounts
My 2004 CLK328 now has over 170k miles. The engine mounts and transmission mount are still originals. Should I change them?
I followed the instructions (somewhere in this forum) to check the engine mounts and they are fine. Should I change them just the sake of age and high mileage?
Old Apr 16, 2013 | 09:05 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
that is really a $600 question. you planning to put another 100k on it?
most would probably say if it ain't broke....
even if your motor mounts are sound I would wager that the tranny mount is shot- but that one is cheap and an easy r/r
Old Apr 17, 2013 | 11:07 PM
mis3's Avatar
2004 CLK320
In autohausaz, engine mount is Lemfoedor OEM. It's $94, not sure if this price is for one of two.
Then for transmission mount, it's URO for $16.
I called the local dealership, engine mounts are $191 per set and tranny mount is $75. If I can get 15% off, I may get them there. I do prefer genuine MB parts.
I think the engine mounts, must not be perfect shape after 172k miles.
Old Apr 18, 2013 | 09:02 AM
Glyn M Ruck's Avatar
Super Moderator
If the engine does not rear up when you accelerate the car in drive against the brakes & you have no vibration from the tranny mount when driving diagonally across a ditch or similar they are still OK. The tranny mount suffers from hard driving & endless foot flat acceleration from a standstill. If you drive sensibly they could all still be OK.
Preventative maintenance is a good thing but I would not change them until they show symptoms of failure & you can feel some vibration in the car. I've known mounts go a lot further than 170K miles with the M112/722.6 setup. That said a new set of mounts can make the car feel like new if they have deteriorated.
Old Apr 18, 2013 | 09:15 PM
mis3's Avatar
2004 CLK320
Thanks. What do you mean by drive diagonally across a path?
Old Apr 18, 2013 | 10:03 PM
mis3's Avatar
2004 CLK320
Did anyone try the transmission mount and engine mounts from Autohausaz?
Old Apr 18, 2013 | 10:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So that's why my motor mounts only last 25K miles!
Old Apr 19, 2013 | 08:06 AM
Super Moderator
If you drive across a ditch diagonally that tries to twist the car's frame & causes large & uneven suspension deflection. Like driving into a steep driveway that is above road level diagonally.
