New Dual Exhaust Just Finished!!
http://www.ebay.ca/itm/390535596290?...ht_2638wt_1159
the spare tire well is holing up, it doesn't even get warm. I put some reflective tape on it and the gas tank as well just in case.
just need to save some money for it.....
Regarding the potential heat concern; why don't you just wrap that part of the tubing. My "guess" (based on my touch and using a small bottle of water with sprayer after a 20 mile drive) ) is that the temp is reduced about 60%. You can touch the wraped portion but you can't keep your fingers in contact more than a few seconds. Of course you can't touch a bare exhaust without much pain and probably serious blisters. Water sprayed on the bare tubing vaporizes immediately; water on the wraped tubing just runs off onto the ground.
your going to need exhaust piping, tips and the bumper cover that fits the clk55 with the duel exhaust cut outs
The exhaust was wrapped around the gas tank part and I used a stick on reflective heat shield just for some insurance.
I didn't wrap the rear section because I felt that it didn't get hot enough, I put a bit of reflective hear shield on the spare tire well to be on the safe side.
So I have looked for the piping and stuff, and will this sort of a thing work?
http://www.supersprint.com/en/prod-c...xit_90x70.aspx
And if yes will I need to get this piece as well?
http://www.supersprint.com/en/prod-c...e_exhaust.aspx
Thanks, and if you can, can you check out my post? I have a few other questions. Thanks!
https://mbworld.org/forums/clk-class...questions.html
