Spark Plugs
I have about the same mileage on mine. I think I'll put changing the plugs a bit higher on my list..... I haven't looked into how to change them. Is it pretty straightforward and did you change the wires as well?
The level of wear shown on the old plugs stresses the ignition system & can lead to coil failure.
Oh, and Fatz, the new plug is the one on the right!
My current plugs were replaced on Mar-2011, some 34k miles before.
So far I've noticed slightly better throttle response.
In ROW the plug change interval has settled at 100,000Km's or 4 years. Cars that are used for short trips & run their plugs outside the self cleaning range can shorten this substantially. My C240 needed new plugs at 45,000Km's ~ very much a town only car. You can't clean these plugs other than taking the car on a 1000 mile trip. Use of an old style grit blaster to clean them destroys them.
Here is the rest.
When I googled "Bosch F 8 DPER", FR8DPP33 (the one in FCPEuro) came up. Is "F 8 DPER" a series of Bosch plugs which consists different plugs?
I do not know whether you would notice the difference between the two plugs or the different gapping. I have to admit that I have always fitted Bosch plugs to friends M272 powered cars at pre gapped spec with no issues. My car only has 17K miles on the clock so I have not had to do a plug change yet. Dealers never regap new plugs.
http://shop.advanceautoparts.com/web...sch_25964612-p
What I posted is in the 2009 Operator's Manual:
Order no. 6515 1338 13 Part no. 209 584 44 97 Edition A 2009
And in the 2009 Maintenance Booklet:
Order no. 6515 8283 13 Part no. 204 584 22 93 Edition C 2009
My car was one of the last produced in 2009.
I would now love to know why Benz made the change for the 550 & not the 350. I'm going to try & find out from shear interest but I'm not very hopeful. As you know the Benz attitude tends to be do as your are told.
If I queried spark plug for 2004 CLK320, 4 results showed up and they are all a lot cheaper than FR8DPP33. One is actually written is an dated version but is cheer.
Looks like the website is suggesting different plugs than what my dealership uses (or used before). I am confused which one I should buy.
The description says it replaces DPER and DPP33 but not sure it is the R version. It is $4.83 each.
I am also looking for spark plugs for my friend's 2003 CL500. According to Autohausaz, same spark plugs.
7422 Bosch OEM
Spark Plug; Platinum; Standard Electrode; OE Plug
12 per engine Updated version of OE spark plugs F8DPER, F8DPP33, and FR8DPP33. Pregapped for normal usage.
