Canbus Ballast still flickering?
Old May 1, 2013 | 12:00 AM
JALE's Avatar
2003 CLK 500
I just received my HID kit from Retrofit Source which consists of H7 4300K bulbs, Ballast, and Canbus harness. I installed them and thought everything was good. Turns out that if I turn the headlights on first and then the car everything is functions as it should. If I turn the car on first then the headlights I get warnings and flickering lights.
Is this normal : ?
Anything I can do to remedy the issue?
Not what I expected from a 150 kit with great reviews
Old May 1, 2013 | 09:47 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The only difference with the engine running is that the alternator would be putting about 2 volts more compared to the vehicle battery. The "CANBUS" canceller works by using a resistor to emulate the wattage draw of a halogen bulb. Those resistors get very hot, so I am sure they use the smallest resistor they can get by with. What may be happening is that your alternator may be putting out just a little more voltage than expected, so changes the output of the circuit with the resistor and thus the SAM sees this incorrect current draw as a bad bulb. Check the voltage with the engine running - it should be around 14v.
Old May 1, 2013 | 09:11 PM
JALE's Avatar
2003 CLK 500
Thanks for the reply Rudeney. I check with my meter and it looks like with the engine off I see 12.5. With engine running is 14.7. Is there anything else I can do before the new canbus harness gets here?
Old May 1, 2013 | 09:20 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
14.7 sounds a little high, but probably not enough to be an issue. My guess is that you have a bad resistor in the harness, hopefully the new one will fix it.
Old May 8, 2013 | 12:37 AM
JALE's Avatar
2003 CLK 500
So I got the harnesses and still the same problem
Rudeney, what's positive and negative on the headlight bulb plug? One side is 1 yellow wire and the other side has 2 blacks wires.
Thanks!
Old May 8, 2013 | 04:20 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
went through similar
$10 set of error cancelers should do the trick
Old May 8, 2013 | 10:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Sorry - I don't know off hand, but I thought the connector had four leads. I still think the issue is a bad resistor in the "CANBUS" corrector.
