Took my 06 CLK 350 on a road trip... smelled burny
Do you guys recommend me having the engine steam cleaned? The guy I sold my c230 04 with only 40k miles on it a few months ago is steam cleaning the engine, says it helps dissipate heat?
I got a steady 28mpg and a tiny bit more on the road trip, that was good.
And the tranny is finnicky in the morning. A little bumpy. My MB SA says the bumpy tranny jerks in the morning are "to be expected"? Is this true? Should I have the transmission fluid tested to double check these guys did a real drain on the transmission? Yes my car has a drain plug.
The burning smell could have be from new brakes, or you could have an oil leak. A common leak on the M272 are the cam plugs. They are on the back of the left-bank head. Run your hand down there to check for oil (a white paper towel can help). Here's a photo another member posted looking down from the top at them:
See:
https://mbworld.org/forums/c-class-w...ngine-bay.html
Took car for service and was told that I have an oil leak from the CAM plugs...$325
After reading this thread, it made sense. I sometimes smelled a burned smell and the engine seems to be rough. Plus the Texas heat probably contributed too.
thanks!
