ANY EXPERIENCE WITH THESE...
I recently switched from a C class (W203) to an old 03 CLK320 (W209).
Im getting the notorious 'clunk', 'knock' sound from the front end and looking at getting it fixed.
Has anyone used or bought these parts of ebay, if so whats your opinion?
- http://www.ebay.com.au/itm/Mercedes-...item2ec15d2faa
- http://www.ebay.com.au/itm/Mercedes-...item1c1839371a
DC
going around a sweeping bend a little fast at say 40mph+ , I'll hear what sounds like a warped rotor. But it's not the brakes or rotor.
is this the sound you hear? I thought it might be front steering suspension. Do you see play in the system while it's up in the air?
I have a 4 wheel alignment when I bought 4 new tires & the clunking was radically reduced, but is still there a bit. I was told the rear alignment was quite a bit off.
I dont know what a warped rotor sounds like. The 'Cluck'/'Knock' sound im referencing can be found in this fix thread...
- https://mbworld.org/forums/c-class-w...placement.html
FYI, this is the 'creek' fix thread also...
- https://mbworld.org/forums/clk-class...gs-w-pics.html
Hope this helped somewhat.
DC
http://www.pelicanparts.com/techarti...m_Bushings.htm
http://www.pelicanparts.com/techarti...Suspension.htm
The best stock quality is MB Star marked parts.
Here are the individual parts
Repair kit, differential to rear sub frame
MB# 2083500008
http://www.pelicanparts.com/cgi-bin/...00008&x=6&y=10
Mount, Rear pair of the rear sub-frame, x2 per car
MB# 2023503408
http://www.pelicanparts.com/cgi-bin/...1.x=13&I1.y=14
Mount, front pair of the rear sub-frame, x2 per car
MB# 1243500341
http://www.pelicanparts.com/cgi-bin/...1.x=12&I1.y=11
Camber Strut New Style x2
MB# 2103503406
http://www.pelicanparts.com/cgi-bin/...I1.x=14&I1.y=9
when replacing earlier version (1) 2103504506 control arm repair kit and (1) 2103520043 sleeve are required per side.
Strut arm, rear x2
MB# 2103503306
http://www.pelicanparts.com/cgi-bin/...I1.x=13&I1.y=9
Thrust Arm - Rear x2
MB# 2103503806
http://www.pelicanparts.com/cgi-bin/...1.x=16&I1.y=12
TIE ROD, REAR x2
MB# 2103502153
Repair kit, control arm, x3
MB# 2103504506
http://www.pelicanparts.com/cgi-bin/...1.x=11&I1.y=12
Sleeve, x3
MB# 2103520043
http://www.pelicanparts.com/cgi-bin/...1.x=12&I1.y=12
Bushing, lower control arm, x2 per car
MB# 2023520165
http://www.pelicanparts.com/cgi-bin/...I1.x=13&I1.y=7
Joint, knuckle to lower control arm, x2 per car
MB# 2203520227
Rubber mounting, rear differential to sub frame, x2
MB# 2023511142
Wheel Bearing Kit, x2
MB# 2029800116
http://www.pelicanparts.com/cgi-bin/...I1.x=11&I1.y=9
whunter@pelicanparts.com
