Plug in seat on 2005 CLK320?
Old Jun 5, 2013 | 02:13 AM
nmayne's Avatar
2005 Mercedes CLK320
Forgive me if this is a dumb question, but I seriously cannot figure it out.
2005 CLK 320 Coupe Seat
I tried to move my seat today an noticed none of the buttons were working. I looked down and noticed the wiring (plug-in plastic square) was out of the seat. I tried putting it in every direction and it wouldn't go. It fit one way, but the seat still did not work.
How do I get my seat working again? I see four holes for prongs to go in on the small black square, two of which seem to be plated on the inside, yet the open plug only has 3 prongs... is this a problem? Also, the small clip like piece on the side seems to have broken off...
Is it possible I need to get a new part? Anyone know what these run?
Thanks so much
Old Jun 5, 2013 | 11:34 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Is this the connector with two tires, red and black? If so, that's the main power supply wire. If it came unplugged, it might have blown a fuse. Fuse #2, on the rear SAM (in the trunk).
Old Jun 5, 2013 | 12:08 PM
nmayne's Avatar
It is the one nearest the door on the driver's side, I will have to go look and see. Where is the fuse box in the trunk?
Old Jun 5, 2013 | 08:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, I think that's the main power supply. It's a square connector with slots for four wires, but only two are there. The rear SAM is in the trunk, left side, behind a removable rectangular section of carpet.
