CLK Door control Module
Old Jul 19, 2013 | 09:47 AM
minty_1982's Avatar
CLK320 CDI
Hi All,
I have a problem with my door control module and it seems to be a common fault with these cars. I was wondering if anyone knows if the unit i've found 2nd hand will work.
My part Number: 209 820 22 26
2nd hand unit: 209 820 12 26
The chap said it was off the older non face lifted CLK W209. I've tried to get my part fixed with no luck.
Thanks in advance.
Old Jul 19, 2013 | 11:29 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The only part numbers I see listed are 209 820 22 26 (right door) and 209 820 21 26 (left door).
Old Jul 20, 2013 | 06:28 AM
minty_1982's Avatar
CLK320 CDI
Hi,
I think the other part number is from the non face lifted model. Ill attach the ebay link. The part looks exactly the same. Thanks for your help.
http://www.ebay.co.uk/itm/Mercedes-C...item53fac39a7a
Old Jul 20, 2013 | 10:56 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't see that part number listed in EPC, and also it does not pull up anything on parts.com. Here's the list of parts from EPC:
http://benzbits.com/w209/DoorControllerPartsList.pdf
Old Jul 20, 2013 | 12:53 PM
minty_1982's Avatar
CLK320 CDI
Is there any chance you can get the parts list up for the older CLK W209? How can i show pics on here because its definitely the part number 209 820 12 26.
Old Jul 20, 2013 | 12:58 PM
minty_1982's Avatar
CLK320 CDI
Here are the two control modules.
The module from my car
2nd hand module on ebay.
Old Jul 20, 2013 | 02:33 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That parts list came from a MY2003 W209 CLK320, so there is no older W209. I do know that sometimes the part number printed on the part itself is not a "real" part number. This may be the case. I don't see that the seller makes any warranties, but maybe if it doesn't work he'd take it back? Considering the price, it seems to be worth it - this is a US$500 part new.
Old Jul 20, 2013 | 06:31 PM
LostinArizona's Avatar
CLK 500 Cabriolet
I just paid $700 for this repair including install.
Old Jul 20, 2013 | 11:09 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Sounds about right - $500 for the part, $200 for labor (at dealer rates). In the USA, you can get the part for just north of $300 at parts.com, and it's an easy DIY if you are skilled in removing door panels.
Old Jul 21, 2013 | 01:46 PM
minty_1982's Avatar
CLK320 CDI
I've got the part off but think i might give that other part a try. Do you know if the new parts had to be programmed to the car?
Old Jul 21, 2013 | 04:32 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No coding is needed.
