clk55 amg 2005 wiring a radio
Clk55
Hey guys i have an 05 clk55 amg and i need the wiring diagram if anyone has it. I looked everywhere for about 2 weeks now and cannot find this. I have the ntg 2 navigation, the one for 05-08 clk cars. im looking to do an aftermarket setup because my amp burned out and i dont feel like spending 650$ for a used amp. thanks in advance
Clk55
MBworld Guru
This is pretty much it:
http://benzbits.com/Audio.pdf
The problem is, you won't have any of the "B" connections for analog speakers. Your car uses fiber optics to get the audio signally digitally to the amp in the trunk, then it's analog on the outputs of the amp. You'll need to run your own analog wiring to the trunk to tie into the speaker outputs there. Also, there is no 12v switched power or illumination circuit on the radio wiring harness, but you can tap into those in the ashtray.
