Quad Xenons
Subscribe
May 28, 2015 | 03:44 PM
Rodney is of course correct.
I suspect the issue is the projector lenses which may not be the quality the seller suggests. I am in now way disparaging him or the lights themselves which are a huge upgrade from stock halogens.
My problem is getting L/R adjustment.
Reply 0
Jan 19, 2016 | 01:14 AM
rudeney i bought these and now they are fogged up inside. minutes after install i have moisture inside the lense. did you have this? everything else about them is awesome. i have 6k a fog lights with a matching led for the parking light. looks epic
thanks
Reply 0
Jan 19, 2016 | 06:27 AM
@clk350Driver do you have any pictures of your setup?
Reply 0
Jan 19, 2016 | 12:11 PM
The projectors are not of the Best quality and this summer i might pull them apart and see if they can be replaced.
However, I did change out the crappy HIDs with some Morimoto ones and that made a difference.
RE: Headlights fogging, I have never had that issue, but i assume that the cover in the back is not on properly?
Reply 0
Jan 19, 2016 | 03:14 PM
Will post pics of my ride after i buff it. Ill check the cover on the back. I might add a bead of silicon along the exposed half of the hl, seal it better maybe. I will check the screw cap on the back before I try anything else.
As far as them not being the best quality projectors, I have no idea what you mean, all hl are just plastic housings. So long as it doesn't leak and you can aim the beam somewhat, nothing else matters....
Reply 0
Jan 20, 2016 | 12:15 AM
No problems with fogging at all. I only have a few minor complaints about these lights. First, the high beam pattern is a bit odd. It's more focused than high beams should ne , and they are aimed slightly too high in relation to the low beams. My other complain is more a personal preference, but I don'd care for the style of the park lights. I wish that illuminate more of of the area around the high beams like OEM headlights. Otherwise, I think they are a nice upgrade over OEM halogen headlights for a fraction of the cost of OEM HIDs.
Reply 0
Jan 21, 2016 | 05:14 PM
  #32
I think Im going to rip out the lights, add silicon on all the edges, throw in a decedent pack, to get rid of the fog.
Reply 0
Feb 3, 2016 | 07:54 PM
  #33
The fogging went away on its own. Thank God. I didn't really do anything other than open the back of the unit in the garage for a day. But it fogged that day too, so not sure why\how but it no longer fogs up anymore!
Reply 0
Explore
Jun 24, 2017 | 10:25 PM
  #34
Fog lights, or anti-fog lights?
Reply 0
Subscribe
Currently Active Users (1)
