finally AVICZ150BH Pioneer 2013 flagship installked in a CLK
Nice....I love AVIC systems.....so how did they handle the fiber optics? Did they rewire the entire audio system? Cause I have an Avic ready to go but I have the Fiber issue and need to figure something out......same car too. 04
MBworld Guru
Very nice! I have an older AVIC 7010 in the C240. It's OK, but the touch screen is a bit fussy - it's the old style "dual-layer" touch sensing instead of the capacitive touch as with most modern smart phones and tablets. The maps and direction are fairly good.
@Djoker - all you need to do is run analog wiring to the trunk. It's easy - there is plenty of room in the wiring conduits under the door sills. Once in the trunk, tie into the high-level analog speaker lines "downstream" of your Bose amp. Your best bet (budget willing) is to put a new multi-channel amp in the trunk. Best case - run a 5-channel RCA cable harness to the trunk and use a 5-channel amp (or a 4-channel + 1 for the sub) then remove the Bose amp and use the new stuff.
Oh, and if you are looking for some decent equipment at a good price, check partsexpress.com. I put a one of their Pyramid amps in the C240 for the sub and I've been very happy with it (or, shall I say "the kid" has - you can here her coming a mile away).
SAWEET.....I'm looking into a 5ch amp now and cando that with NO problem....just need to know what wires are front rear and sub....will that be on the BOSE AMP?.....
MBworld Guru
Yes, pickup the speaker level outputs on the Bose amp. These may help:
http://benzbits.com/w203/SpeakerWiringDiagram.pdf
http://benzbits.com/UseOfWiringDiagrams.pdf
