2009 clk 350 abs/esp ?
1997 explorer sport
im working on a 2009 clk350 the abs/esp light came on and i have no rear brake lights. according to my alldata the brake light switch is on the pedal bracket i accessed the pedal assembly and theres no switch in there is it located on the master or booster. any help is appreciated thanks in advance
MBworld Guru
The mechanical switch was removed from the pedal many years ago. It is now integrated into the ABS control unit (under the hood, driver's side). It's likely that the control unit is bad and will need to be replaced.
