seat belt extender problems
http://www.mods4cars.com/sms/db/smar...all_clk/en.php
I'd just unplug its wiring harness and give things a try. If that fixes it, the first thing I'd do is make sure you have it updated to the latest firmware. With it unplugged, you can take it to the workbench and connect it to your PC via USB cable and use their updater software:
http://www.mods4cars.com/m4cupdate/
Use the "m4connect" link.
HELP
I have a 2004 clk500 convertible. Passenger seat belt presenter does not present. Dome light switch works when door opens. Drive presenter works. What are the possible fixes or problems. I can pull out bar manually so it isn't binding.
Thanx
stu
I think the controller is bad.
Your thoughts?
This is nuts...
The soft top controller seems to be working, nothing wrong with the top except the fluid was low and the pump sucked up some air causing foaming, Just topped it off with some p/s fluid and it works fine with no more noises, actually faster and quieter as prior to this issue.
The interior lights work, everything works in accordance to the door plunger.
Mechanic stated that there is such a slim possibility that the controller is bad if the top works and said its the last thing to change out since it's a non-returnable item from MB. Ebay has a dozen for sale out of wrecks for less that $200. Some actually will take a return so if it doesn't fix the issue your take no chances.
Update soon.
Is it possible to just disconnect the controller and re-connect it ? I don't' have a code reader that allows resets.
Maybe I'll try it and then let all know. This issue didn't start until I replaced the battery.
In overall I'm not a fan of disconnecting the battery as long as there is no absolute need to. Even those ice age cars have quite a few modules, that doesn't like the power fluctuations. The processor in the light control module on my BMW was erased when I tried to start the car with a weak battery. It was a challenge then to program the firmware back.
That assemble contain one motor with step sensor inside of motor brush and one switch on the arm. On first time I check the arm switch, everything was Ok, then I check the motor, also working fine... Only the problem was because I cannot check the sensor from inside of motor brush so I think the problem is come from that sensor...
After replacement of arm extender assembly the problem was solved.
