CLK 270 CDI air problems (temperature problems)
I have a clk 270cdi with a "problem" in the temperature control..
My air unit is like this one: http://olx-t.imgrap.com/ui/25/26/25/...361&country=PT
The problem is: if i put on 26ºC it blows hot air, but if i put it to 25ºC, 22ºC or 18ºC for example, it only blows cold air.. it happens always, this control just worked fine about 10 times of 1000 that i have used it..
i cant have a good temperature in my car like 22ºC because i will get super cold
.. it happens with AC off or ON and manual ON or auto on..please help me, thanks
Thank you very much for your help.. i made that test and the lights didnt stop flashing.. they only stop when i turned off the car xD
after that i was in mercedes to they check the problem and they told me that is a cheap part that locates behind the radio and need to be changed.. they told me that they have to remove the dashboard to change that part and it will have a high cost..
so.. the part is cheap but the unmounting/mounting service will be very high..
so i m asking if you know what part is that behind the dashboard radio that i need to change and if it easy to change... beacause i have changed one time my radio and i removed my dashboard to do that and it was easy.. so maybe i can change it by myself at my home..
sorry for bad english..hope you understand.. thanks
