Question regarding 05 SLK55 6/4pot calipers
Old Oct 28, 2013 | 12:15 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
so im thinking about getting a set of 6/4 pot off a 05 SLK55 and noticed the seller has 1 piece rotors for the front and back.
can someone tell me if that is correct.
Front caliper part #
PART NUMBERS: 20.8885.04 1A & 20.8885.03 1A
DISTANCE BETWEEN THE MOUNTING HOLE'S IS APPROXIMATELY: 11CM (CENTRE TO CENTRE)
Rear Caliper part#
PART NUMBERS: 20.8043.03 1 (SAME ON BOTH)
DISTANCE BETWEEN THE MOUNTING HOLE'S IS APPROXIMATELY: 7.5CM (CENTRE TO CENTRE)
Rotors
Front:
DIAMETER: 338MM,
Rear:
DIAMETER: 330MM.
what are the other rotor options i can use for the front.
Thanks!
also, we should have a Sticky of some sort with all this information in it
Old Oct 29, 2013 | 07:13 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
no
6 pot calipers for the clk/slk55 series use 2 piece full floaters up front
other than oes i think there may be 2 or 3 aftermarket suppliers and $1100 give or take is what a pair will set you back.
1 piecers in the back available cheap on amazon and elsewhere
Old Oct 29, 2013 | 11:18 PM
omega48er's Avatar
Thanks for the reply wave, but why am I seeing 1 piece 340 mm rotors for the front 6 pot
http://pages.ebay.com/link/?nav=item...d=251363750309
Old Oct 31, 2013 | 08:59 AM
they are aftermarket as clearly stated
also 1 piece as stated
ask how much they weigh
they may be a good alternative
Old Oct 31, 2013 | 10:30 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
The 6 piston calipers can come with 340mm rotors or 360mm rotors. The 340mm are the cheap, once piece ones. The 360mm rotors are 2 piece and are part of the performance package and are about 600$ a piece.
The rear rotors are 330mm, 1 piece, regardless of performance package or not.
Calipers are the same (different mounting brackets to accommodate for the larger calipers).
There really are no rotor options for the 2 piece front except for OEM and racingbrake. I stuck with OEM because prices are the same and the racingbrake ones are marginally smaller.
Old Oct 31, 2013 | 11:29 AM
simply incorrect at least for the clk55
there is voluminous discourse on this topic
340 mm 2 piece front rotors are stock on the 05/06 clk55amg
the 360's were for the clk63
i do not know when the slk55amg changed over but i suspect 07
it is possible that someone finally did produce a lost cost option although i find it hard to believe there is much of a market for them
i put some drilled and slotted ***** rotors on my rears about 5k miles ago and they looks stock and work just fine. the pair cost less than a single oem!
Old Oct 31, 2013 | 01:27 PM
megacrazy's Avatar
Yup. What I mean is that if you have the 340mm calipers you can throw the 1 piece 345mm rotor on without issues. I remember reading plenty of people did that. That probably explains why the set has 1 piece rotors in the front.
If you have 360mm rotors you're screwed. No 1 piece options that I know of.
Old Oct 31, 2013 | 02:41 PM
omega48er's Avatar
Thanks for the clarification guys. Like I said we do need a a sticky with all this info.
Old Oct 31, 2013 | 06:27 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
CLK55 / SLK55 Complete Rotor Offer
Just to clarify OE options and Racingbrake rotor availability:
2003-04 CLK55 AMG:
OE Front = 345x30mm one piece rotor
OE Rear = 300x22mm one piece rotor
RB Front = 340x30mm two-piece rotor; 7.7lbs lighter than OE; $976/pair
RB Rear = 300x22mm two-piece rotor; 4.2 lbs lighter than OE; $749/pair
2005-06 CLK55 AMG
OE Front = 340x32mm two-piece rotor
OE Rear = 330x26mm one piece rotor
RB Front = 340x32mm two-piece rotor; 5.95 lbs lighter than OE; $1049/pair
RB Rear= 328x26mm two-piece rotor; 5.5 lbs lighter than OE; $1138/pair
2005 SLK55 AMG
2006-08 SLK55 AMG (w/4 piston front calipers)
2006-09 SLK55 AMG (w/6 piston front calipers)
OE Front = 360x32mm two-piece rotor
RB Front = 355x32mm two-piece rotor; 2.75 lbs lighter than OE; $1170/pair
RB Rear = 328x26mm two-piece rotor; 5.5 lbs lighter than OE; $1138/pair
Old Oct 31, 2013 | 06:43 PM
CLS550
Racingbrake offers a replacement for the 360mm rotor that only costs $585 a piece.
RB designs and engineers brake products that not only perform better but also fit better than other OE replacement options. For example, the reason we use a 340mm rotor instead of 345mm or a 355mm rotor instead of 360mm rotor is to eliminate rust rings that develop on the inner and/or outer edges of the rotor where the brake pads are not making contact with the ring like in the picture below:
Old Oct 31, 2013 | 07:51 PM
megacrazy's Avatar
First of all it's great that you guys develop rotors for some of these Mercs. In some cases you're the only aftermarket option which is great.
However, the OEM 360MM rotors are 564$ a piece vs your 585$ a piece and that's on sale. MSRP is 650$. Replacement rings alone from you run 505$ a piece. For comparison purposes you can buy Wilwood 16 INCH rings for about 430$. This is nowhere close to competitive pricing...in fact it's more than OEM.
As far as your products being superior where are the test results? Do cars with your rotors brake better? By how much? How long do your rotors vs the OEM ones last? There are a lot of claims on your site without a shred of data anywhere. Again, it's great that you give us all options but I doubt the Racingbrake name has the same value as say...Mercedes or Brembo to warrant the higher prices, especially without any conclusive tests.
I am not sure about any rust rings. If the pad is missing a large chunk of the rotor that's indicative of bigger braking problems, not Mercedes failing to size rotors properly for a car they engineered. I haven't noticed any rust rings on the 345mm OEM rotors or the 360mm ones on my car.
Old Oct 31, 2013 | 08:55 PM
omega48er's Avatar
Thanks again for this info, I like really like the direction it is going.
Old Nov 1, 2013 | 01:25 PM
CLS550
All our rotor assembly and replacement rings are sold in pair, so are the prices.
Old Nov 2, 2013 | 07:49 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
Yup. never had rust rings on my 360/330 rotors.
Old Apr 6, 2021 | 02:48 AM
givenchy513's Avatar
2006 SLK55 AMG
Bough a used 2006 SLK55 from a local guy last year.
I have problems buying pads or discs now as well. According to your reference, mine is mis-matched.
Model 2006 (Canada Version)
SLK 55 AMG
6-Piston Front (2-Piece Floater), it seems on 340mm diameter.
4-Piston Rear (1-Piece)
Front Caliper Part Number: 20.8885.04 1A (Right Side)
NO Performance Package or 030 etc.
Couldn't get parts with right description. Even the local dealer oem parts online store got them wrong.
No idea if it is a regional problem.
Most of the suppliers are selling pads for 6 piston (360mm Disc with Performance Pack), or they simply classified as 4/2 pads.
Pads are due soon, need the right part numbers urgently.
Thank you very much.
2005 SLK55 AMG
Old Apr 7, 2021 | 10:51 AM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
SLK 55 AMG
Front rotors: part # 1714210112, or directly Brembo part # 09.9254.33 (much, much cheaper) - 340mm
Front pads: they are the same for 360mm (with PP) and 340mm brakes, simply because the calipers are the same, the only difference is a bracket witch holds the caliper to
knuckle. Part # 0054203920
Rear rotors: are the same for PP and none-PP brakes, part # 1714230212 , Brembo part # 09.9257.41
Rear pads: A bit trickier, I have 3 part # 0054204120, 0034206220, 0044204920. From what I know they are all compatible, the only difference is that on some of them there are aluminium tabs (for easier removal, probably). I don't remember which part # I used for my car (I had slk55 calipers as well), but my pads had those tabs. (see picture)
You can find more pictures here: https://mbworld.org/forums/clk-class...omparison.html
Old Apr 9, 2021 | 12:39 AM
2006 SLK55 AMG
Oh my lord.
Your information saved me from the hell.
Appreciate your input.
Old Apr 9, 2021 | 12:44 AM
dzmitry's Avatar
Oh my lord.
You are very welcome!
Old Apr 9, 2021 | 02:16 AM
2006 SLK55 AMG
As you said, front pads are the same on 340 and 360 rotor, but the Brembo website gave out 2 part numbers for front pads,
P50053 (Exc. PP)
P50092 (PP)
So if 0054203920 is the one you used, then this may equivalent to P50092 (PP).
I am not sure if I am in the right thinking.
Old Apr 9, 2021 | 02:54 PM
dzmitry's Avatar
Ok ,seems like P50053 pads are for 4 piston front calipers (from clk500,clk550,c32 etc) and P50092 pads are for 6 piston from calipers. I think this confusion is because slk55 probably was offered in Europe with 4/4 calipers setup and 6/4 was an options (unlike in US).
Old Jan 25, 2022 | 11:48 PM
gestut's Avatar
clk 63 AMG BS
Hi I am not clear , you mention for the rear its the same rotor if it is performance or not, then how come there are 2 rear rotor size 300 and 330 from what i see here , I just got a 2008 slk 55 amg, not sure what i have yet , just trying to figure out what i need. thanks
Old Jan 26, 2022 | 12:35 AM
dzmitry's Avatar
That's the problem with marketing
If I understand correctly for US/Canada market all slk55 were equipped with 340mm (6 pistons) front and 330mm (4 pistons) brakes, but in Europe those brakes where optional.
If you want to be 100% sure you can post your VIN and I'll check in EPC exact part number for your car.
Old Jan 26, 2022 | 12:39 AM
gestut's Avatar
clk 63 AMG BS
I agree about the marketing part, its seems like i have 4 piston in front but here is the VIN: WDBWK73F88F175438, if i can get the front and rear rotor /pads part #s that would be great
thanks
Old Jan 26, 2022 | 03:14 PM
dzmitry's Avatar
Yeah seems like you have 4/2 setup (the same as early clk55, clk500/550, c32, etc), although I think clk500 (US) doesn't use perforated rotors but still 330mm. Here is part numbers from EPC:
Front Brake Disk: 2034210912
Front Brake Pads: 0044209020
Rear Brake Disk: 2104230812
Rear Brake Pads: 0034203020
BTW those should be yours https://mbworld.org/forums/clk-class...ml#post7258374
Old Jan 26, 2022 | 05:12 PM
gestut's Avatar
clk 63 AMG BS
Thank you sir! , yeah kind of bummed that 2007 and older had 6/4 , the rear ones doenst even say amg, what were they thinking , lets take 6/4 out and have them pay more for 6/4 with the p30 option
