P0177 code with no problems
Old Nov 2, 2013 | 07:28 PM
benwaide's Avatar
clk350
I have a Check Engine light on my 2007 CLK350 that shows as code P0177. O2 problem? No discernible performance problems. Any suggestions?
Old Nov 2, 2013 | 11:14 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Arer you sure it's P0177? I am not finding a cross reference for that generic OBDII code to the DTCs for ME 9.7
Old Nov 3, 2013 | 08:29 AM
benwaide's Avatar
clk350
The code reader actually read P2177 but the instruction book led me to believe I should drop the 2.
Old Nov 4, 2013 | 10:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I can't find a cross-reference from that generic OBDII "P" code to an MBZ DTC. I do find DTC 2177, which is "2177 The power supply at the input of the engine control unit has a sporadic malfunction. "
Old Nov 5, 2013 | 11:05 AM
benwaide's Avatar
clk350
P2177
I found another explanation for that code at Actron on-line. Not sure if it is correct for MBZ. "system too lean off idle bank 1". Not sure what that means either. Car seems to be running fine.
Old Nov 5, 2013 | 10:22 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you clear the code, does the MIL illuminate again?
Old Nov 6, 2013 | 07:26 AM
benwaide's Avatar
clk350
Yes, it does.
Old Nov 9, 2013 | 10:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
OK, that might correlate to these DTCs:
2089 The mixture in the right cylinder bank is too lean in the partial load range.
2091 The mixture in the right cylinder bank is too lean when idling.
Both of these suggest a problem with the pressure sensor (B28):
Old Nov 10, 2013 | 09:50 AM
benwaide's Avatar
clk350
Thanks, Rodney. I changed the air filters and cleared the code and this time it did not re-appear! Not sure if I jarred something as I changed the air filters or what but as of right now I am clear.
