Question for a friend
Old Nov 19, 2013 | 10:49 PM
mis3's Avatar
2004 CLK320
I am trying to help out my friend who drives a 1996 c220 sedan. I know I should ask this question in the w202 forum but maybe because w202 is older, that forum is not too active.
His ignition key would not turn and his indie asked for $1,200 for the repair. I checked Autohausaz and the ignition switch was $35. So, I am definitely looking at the wrong thing.
Let's say for our w209, if the ignition key would not turn, what should I be looking for?
Old Nov 19, 2013 | 11:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Does that use a switchblade style metal-blade key, or the new pear-shaped infrared SmartKey? If it's the switchblade, then it could be a mechanical problem with the switch, as it is a traditional style tumbler system that releases it to rotate.
If it's the SmartKey system, then it's more complicated. First, does he have a spare and does it work? if there is no spare, my advice is to order one from the dealer's parts counter. If he has more than one key and none of them work, then it's a problem with the keys not being recognized (even though they may unlock the doors, the ignition switch recognition is totally separate). In this case, it could be a vehicle battery problem. That's by far the most common cause of this. f that's not it, then it could be a bad ignition switch, and unfortunately that often "fries" the keys. Unless the indy has access to SDS, that would be a dealer repair.
Old Nov 19, 2013 | 11:46 PM
mis3's Avatar
2004 CLK320
This car has the metal blade key. What part(s) should I look for in the parts store?
Old Nov 20, 2013 | 07:31 AM
Glyn M Ruck's Avatar
Super Moderator
You need a new lock barrel & key set. Fortunately no EIS (electronic ignition switch) to consider. That's what gets expensive.
Old Nov 20, 2013 | 10:55 AM
mis3's Avatar
2004 CLK320
By key set, do you mean a new key? If so, this will have to be done by the dealership. I doubt if an indie can cut a key for a MB.
As for the lock barrel, I found these 2 items in a Canadian online store:
Ignition Lock Housing:
http://www.autopartsway.ca/PartList....996/C220/Base/
2.2L_L4/allB/Ignition/Primary_Ignition/Ignition_Lock_Housing/pagenum1/tabS
Ignition Lock Cylinder:
http://www.autopartsway.ca/PartList..../pagenum1/tabS
Old Nov 20, 2013 | 05:39 PM
Super Moderator
The lock barrel should come with 2 keys.
Old Nov 20, 2013 | 09:21 PM
mis3's Avatar
2004 CLK320
Thanks for the reply.
I will call my dealership tomorrow to get a quote of the lock barrel.
Approximately how much time does it take to replace this lock barrel? Is $1,200 a fair price for he job? I think the indie would have to get the parts from the dealership.
Old Nov 20, 2013 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Given all the work - replacing key blades, the ignition switch, door lock, trunk lock and glove box lock, $1200 (inclusive of parts) seems about right.
Old Nov 20, 2013 | 11:20 PM
mis3's Avatar
2004 CLK320
My understanding is the door locks have already been changed to some other locks. In other words, one key for the doors and another one for the ignition. So, the whole job is to replace the ignition lock only.
Old Nov 21, 2013 | 02:29 PM
mis3's Avatar
2004 CLK320
I went to the dealership today and got quotes.
Lock barrel: $229CAN. Comes with one key. I think they call this the lock tumbler.
Steering lock: $180 CAN. According to the parts diagram, this is the part right after the lock barrel.
The parts guy said I may need both parts.
I then went to Parts.com, the lock barrel (cyl and keys) is $43US and the steering lock is $105US. I am wondering, how can someone gets a MB key from a store other than the dealership?
Now that the key would not turn, how would I remove lock barrel and the steering column?
Old Nov 21, 2013 | 03:51 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
Well, since it contains no elctronics, it is just a lock. Not much different than the one on your house, which is probably much more valued than your/our car. MB probably doesn't make the locks themselves and the vendors are, except in some special cases I imagine, are free to sell to any distributor. I would imagine this is a way for the manufaturer of the part to recoup some of the per part loss they incur by "winning" the bid.
Glad you/your friend are on the path to ignition recovery.
Old Nov 21, 2013 | 07:28 PM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
Parts.com is the same parts as the dealer uses so you should be getting a key from them I would think.
Old Nov 21, 2013 | 08:28 PM
mis3's Avatar
2004 CLK320
The parts guy from my dealership said my friend has to order the key in person with the car registration. This makes sense, they should not make a key for someone without the proof of ownership.
To think of it, maybe they will make a same original key.
Old Nov 21, 2013 | 08:56 PM
Super Moderator
Interesting the way Benz changes packaging around the world. In SA all lock barrels come with 2 keys.
Old Nov 21, 2013 | 08:59 PM
mis3's Avatar
2004 CLK320
Are these keys the original keys? In other words, are these keys able to open the car doors?
Old Nov 22, 2013 | 06:48 AM
Super Moderator
No. Then you have to buy the full lock kit.
