Issue with settings not saved
Old Nov 28, 2013 | 11:06 PM
demidion's Avatar
2007 CLK550
I bought my 07 CLK550 6 months ago and found what I think at least should be a problem lol. Whenever I set something, fan speed, ESP off, map on, I turn off the car and restart it everything is back to a default. Is there any way to have it save things where I have left it before the vehicle is turned off? It's pretty annoying.
Thanks!
Joe
Old Nov 29, 2013 | 11:05 AM
Yidney's Avatar
2008 CLK550 Cab
Not really. I never paid attention to fan speed since mine is always on auto anyway.
Old Nov 29, 2013 | 01:20 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Hmm, I am fairly certain my HVAC setting stay as they were when I shut off the ignition. I know ESP Off has top be selected upon each start up, and I think that the COMAND unit always defaults to either the audio input last used, or, if you had the map on the screen, then it goes to the NAV menu.
Old Nov 29, 2013 | 01:43 PM
demidion's Avatar
2007 CLK550
Thanks... hmmm your fan stays? Mine does reset, I figured the ESP would. The Nav is pretty annoying though. I would really prefer it would come up on map. I should probably stop in the MB shop and find out if they can change a setting to make it no longer go to default.
Old Nov 29, 2013 | 07:24 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't believe there are any settings they can change for this. As for the fan speed, it may not stay - like Yidney, I generally keep mine in AUTO mode, but even when not, I know it will keep things like "active charcoal filter mode" and the temperature settings.
