2006 clk 350 Sports or Standard Suspension?
Old Feb 2, 2014 | 09:53 PM
mecca281's Avatar
W222 s550 , BMW 535i 15’
Fellas,
How do you know which suspension system you have?
I have a 2006 clk350 cabriolet. Is this equipped with a sports suspension (standard model)?
I have had a real rough ride for a while now and and I just noticed my sway bar links bushings were shot.
While looking for new links online I noticed that there are 2 types, 1 for sports suspension. I think my Indy put regular links on my car.
1. Is it possible to put the wrong links on a clk?
2. Could this be a cause of my horrible ride?
3. Does my car actually have sport suspension?
Thanks in advance
Old Feb 2, 2014 | 11:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Post your VIN and can lookup the data card in EPC to see if you have the sport suspension option.
Old Feb 3, 2014 | 12:02 AM
mecca281's Avatar
Is that a smart thing to do? Lol
How can I check myself?
Not saying I don't trust our board members but this forum is public domain.
Old Feb 3, 2014 | 08:48 AM
Yidney's Avatar
2008 CLK550 Cab
People post VINs all the time. It's not like a credit card number - it's visible to the world in little window through your windshield.
Old Feb 3, 2014 | 12:42 PM
mecca281's Avatar
WDBTK56G16T056236
Old Feb 3, 2014 | 06:51 PM
mecca281's Avatar
Does this vin have sports suspension?
Old Feb 3, 2014 | 10:25 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
OK, first of all, the next time you are driving your car and it feels like maybe someone has take control of it, well, that's not me! :P
Seriously, VINs are safe to post. No one will find outu who you are or where you live or steal your car. In fact, my copy of EPC already has the entire VIN database through October 2010, so it's no secret.
Here's your datacard:
http://benzbits.com/Wdbtk56g16t056236.pdf
You have option #961, the sport suspension.
The correct part number for your anti-sway bar end links is A2033202889. I checked several version of the W203 and W209, and other than the AMG models, they all use the same part number. I believe the AMG's have a larger diameter hole int he anti-swa bar and thus a larger bolt for the end link to attach.
Old Feb 13, 2014 | 04:03 PM
mecca281's Avatar
So, I purchased the links and finally got the car jacked up correctly and all pressure off the links and took it out... Horay? Not quite... The bolt on the links are the larger diameter bolts...
I did research before I bought the links also but my main focus was towards buying links that stated (for vehicles with sports suspension)
Well my Indy says there is only one strut assembly for my vehicle and that he would have to drill out the hole to fit the larger links...
First of all is it true that I can't find a strut with the right size hole for the sports suspension links?
Second should I just purchase the smaller bolt links? Which seem the same outside of that?
Thirdly could this be why I can never get a smooth ride... Regardless of tire selection and pressure?? Because I may have the wrong struts or links??
Old Feb 13, 2014 | 11:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I really doubt that the end links on the anti-sway bar would affect ride quality very much. Usually, symptoms of problems with them are just noises as the ball joints on them fail.
Old Feb 14, 2014 | 08:09 AM
mecca281's Avatar
Thanks. So what about the fact that the struts don't fit suspension links? Drilling them sounds like the wrong thing to do on a mercedes..
Old Feb 14, 2014 | 08:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There are different sized end links for different size anti-sway bars. It's odd, though, because the AMG models use a larger diameter, the non-AMG use a smaller. That part is the smaller diameter bolt. Is there a part number stamped on the the links? It makes me wonder if you were shipped the wrong part.
Old Jan 10, 2019 | 12:39 PM
Junior Alicea's Avatar
2008 clk350
Hello
I also have a 2008 CLK350 and wondering whether sports or not my vin# WDBTJ56H28F258886
your help would be appreciated
thanks
Old Jan 10, 2019 | 07:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
http://benzbits.com/datacard/WDBTJ56H28F258886.pdf
It shows code 486 for Sport Suspension.
Old Jan 11, 2019 | 09:12 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
That's quite strange, for vin WDBTK56G16T056236 it doesn't say that it has sport suspension, only sport package which I think only appearance packages, and sway bar links Rodney mentioned is correct (2033202889, for sport suspension links are 2033202989), so technically what you need is to by non-sport suspension links, which are more cheaper (about 2 times cheaper), about $19 each from FCP.
Old Jan 11, 2019 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Correct: WDBTK56G16T056236 has code 951 which is just an appearance package, so no suspension upgrades.
Old Oct 7, 2019 | 11:08 PM
C230Ak's Avatar
2012 C63 (P31)/2006 CLK350 Coupe
So the 951 appearance package; did that also come with fixed 2 piston front calipers that still used the standard 300mm x 28mm discs? I have a froze up caliper and there are a bunch of used sets of fixed caliper pairs on ebay for a good price but I'm trying to determine if I'll be able to use my current discs from the basic brakes. I know there are 330 and 345 size rotors, but I was looking at some used car ads and saw a CLK350 with my same 17" 5 split spoke wheels but fixed calipers behind them. I'm very tempted to just go for it and see what's what, haha.
Old Oct 10, 2019 | 02:45 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My understanding as that code 951 is only for cosmetic items like the bumpers rocker panels, etc.
Old Oct 21, 2019 | 07:37 AM
damngoodavr's Avatar
CLK 350
CLK350 2006
Hello to everyone,
I am sorry to ask in another members thread, but would like to check if my vehicle is having a sport suspension already or a normal one.
VIN:WDB2093561F201029
Thank you very much.
Old Oct 21, 2019 | 09:19 AM
dzmitry's Avatar
Originally Posted by damngoodavr
Hello to everyone,
Yes you do have sport suspension (code 486)
Old Oct 21, 2019 | 10:52 AM
CLK 350
Hey dzmitry,
Thanks a lot for the fast response. Appreciate it!
Would it be possible to provide the data card for the vehicle?
Old Oct 21, 2019 | 11:31 AM
dzmitry's Avatar
Hey dzmitry,
Np
Here is the data card
File Type: pdf
Old Nov 2, 2019 | 09:34 AM
Ed ohio's Avatar
CLK350
Originally Posted by dzmitry
Np
Please check
WDBTJ56H27F225319
Thank you very much!
Old Nov 2, 2019 | 11:30 AM
dzmitry's Avatar
Originally Posted by Ed ohio
Please check
WDBTJ56H27F225319
Your car has sport suspension (code 486)
Old Nov 2, 2019 | 02:51 PM
Ed ohio's Avatar
CLK350
Please provide datacard
Thanks so much for the super quick response!! Could you please provide the datacard for this vehicle?
WDBTJ56H27F225319
Thanks in advance!!
Old Nov 2, 2019 | 09:38 PM
dzmitry's Avatar
WDBTJ56H27F225319
Thanks in advance!!
Attached.
But if anyone also need it you can use for example https://www.datamb.com/
File Type: pdf
