Limp mode. Please help!
Old Feb 17, 2014 | 05:43 PM
Mts707's Avatar
2003 clk 320
Hey how's it going? I just bought a 2003 clk 320. It has 128k. I hooked up the diagnostic test and it's giving me the codes P0715 and P0730. I put it in drive and sometimes it doesn't shift at all. Sometimes I restart it and I put in drive and it will drive put at a top speed of 40mph. I have no idea on what to do. Any advice would be greatly appreciated. Thanks in advance!
Old Feb 17, 2014 | 11:56 PM
Yidney's Avatar
2008 CLK550 Cab
I assume you researched those codes? Looks like you may need a new conductor plate in your tranny.
Old Feb 18, 2014 | 12:28 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Those generic OBDII codes just tell you "read the TCU fault codes". You'll need SDS or other high-end tool to read that system. But as Yidney said, it's likely that the codes will lead to replacing the conductor plate.
Old Feb 18, 2014 | 12:34 AM
Mts707's Avatar
2003 clk 320
How much do you think that will cost? How likely is it to be the problem, just out of curiosity?
Old Feb 18, 2014 | 07:19 AM
xsever's Avatar
2012 C300 4MATIC Sport
It's a common problem with the 722.6 transmission. A dealer charge you about $1000 to replace the conductor plate, change your fluid, and the filter.
