2006 CLK 500 ignition switch issue
Old Mar 31, 2014 | 09:29 PM
paintalchemist's Avatar
W209
Want to know if anyone has run into this issue.Intermittent start issue. You will place key in switch is always accepted and you can turn to start but the nothing.You then have to remove and replace key over 5-15 minutes for it to start car.There are no codes or other signs that the switch is bad but this.Never happens when cranking overnight.Only seems to happen when you drive and are stopping and starting car frequently. Local shop had no lucky with it for two weeks and as soon as i drive it over the wkend it happens again.Do you think I should just replace the switch since i have two keys and it does it with both.
Old Mar 31, 2014 | 11:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I doubt this is this switch. First, check the battery. If voltage is much below 12.6v, then that would be my first suspicion - either the battery is bad or the alternator/voltage regulator or maybe a voltage leak is draining it. If it's not that, then I'd look at the starter.
Old Apr 1, 2014 | 05:22 AM
gmphertford's Avatar
S Class
Does the vehicle crank when does not work? do you get ignition lights?
Old Apr 1, 2014 | 07:58 AM
W209
No it does not crank, as you insert and turn key all lights come on in dash that should with a normal crank cycle. But there is nothing as you turn the key all lights come one but the engine does not turn over.
