soft top problem
Old Apr 17, 2014 | 12:25 PM
jacksonman's Avatar
2004 clk320 cabriolet
Question soft top problem
Hi all, took car out of shed, where it spent the winter ,( most winters it's been warm in Fl.) a week or so ago. Reconnected the negative battery lead,( periodically, would start and move it during winter.) Well the warning alert :"top locked vehicle moving " appeared,and has not gone away. Switch on console does nothing....opened roof manually .Do not recall touching the switch while moving it back and forth a few feet, over the winter but it's possible.....one strange thing:when i opened top, sitting on bow not secured in place ,were the two square black rubber inserts(1"?)....snapped them back into place..... how should i proceed next, do not have a regular mechanic....car has 30k miles , and until this event-----no complaints....thanks!
Old Apr 17, 2014 | 08:10 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My guess is that it's related to low voltage - check the battery and alternator.
Old Apr 17, 2014 | 08:31 PM
jacksonman's Avatar
Will do!....thanks....
Old Apr 25, 2014 | 01:39 PM
jacksonman's Avatar
soft top problem update
Update to soft top problem,is that soft top goes up/down with key remote,but does not work with console switch.Warning:top locked vehicle moving ,still appears. Is this a case of clearing codes or ?.....Would like to have some idea of where problem may be before i find a mechanic to take it to......after reading any number of posts here, have some trepidation ......thanks
Old Apr 26, 2014 | 12:22 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
When you say it works with the remote key, are you just pointing it at the IR receiver on the door handle and holding the button, or do you have an aftermarket "SmartTop" module installed where you can click the fob button three times to operate the top? If you have the aftermarket module, it overrides the vehicle speed sensor up to 25mph, so this sounds like a problem with something outside of the soft top controller, i.e. it is getting an incorrect speed reading. If this is just the IR press-and-hold function, then I'd say it's a problem in the soft top controller. Either way, you're going to need a shop with the right diagnostic tools (SDS) and skills to chase this down.
Old Apr 29, 2014 | 04:04 PM
jacksonman's Avatar
Just have the key fob ir sensor.....thanks
Magnificent New Mercedes-Maybach S-Class Revealed: 12 Things to Know
Slideshow: Mercedes-Maybach has refreshed the S-Class with new lighting signatures, AI-driven software, and even more elaborate rear-seat luxury.
By Verdad Gallardo | 2026-03-25 18:01:51
