M271 engine chain modification
Old Jul 6, 2014 | 06:10 AM
tantinjan's Avatar
clk200k 2005
Hi is there any one who know if the up grated m271.820 year 2009 to 2012 engine chain will fit the m271.940.year 2005 . I understand the chain from this model is a new design and stronger than the old chain.
Old Jul 6, 2014 | 11:42 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
EPC does not list is as a possibility. I doubt it would work. I suspect the sprockets were also changed.
Old Jul 7, 2014 | 01:28 PM
Glyn M Ruck's Avatar
Super Moderator
+1^. Sprocket profiles are different.
Old Jul 7, 2014 | 06:20 PM
tantinjan's Avatar
clk200k 2005
Thumbs up
Thank you gents for your reply. I might go for a c200gci engine transplant when my car engine die.The mercedes benz agency in Cairns had never come back to me when i had ask them for engine chain installation, our local indie had quote me $ 3000 . I can get a second hand motor from Sydney for $3000. Might do the chain myself ?
Old Jul 7, 2014 | 09:41 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So you haven't had a failure, you just want to replace the chain as a proactive measure? It can be done DIY. Here's the WIS docs:
http://benzbits.com/m271/TimingChain.pdf
Old Jul 7, 2014 | 09:47 PM
tantinjan's Avatar
clk200k 2005
Thank you very much.The car got 116500 km on the clock and is in a very good state .I will do the chain asp.
