2013 CLK350 Ticking sound
Old 08-02-2014 | 11:57 AM
aceit's Avatar
2013 GL450 & E350 Cabriolet
2013 E350 Ticking sound
2013 E 350 with Cabriolet 2500 miles has a constant 'ticking' noise. I thought it was coming from the fan belt but the service rep say's it is the 'fuel injector'. Adding that he has had many complaints but MB has no fix. Any suggestions or comments would be appreciated. Great car but this is really annoying.
Thanks!
Old 08-02-2014 | 12:09 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Is this 2013 GLK350? There is no such thing as a 2013 CLK - they ended production of it with MY2009, then re-slotted it as the "E-Class Coupe". You might want to check the X204/GLK forum for better info.. I believe the 2013 GLK has a direct-injected engine, and those will be a little noisier than the traditional "above the valve" injectors.
Old 08-02-2014 | 04:22 PM
aceit's Avatar
Thanks for the heads up, made the necessary model changes. E35 Cabriolet
Old 08-02-2014 | 09:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Ah, OK, an A207. I believe it also has the direct-injected engine. They do make more noise.
Old 08-03-2014 | 11:27 AM
aceit's Avatar
Not the reply I as hoping for but ...Thanks!!
Old 08-03-2014 | 05:21 PM
zill's Avatar
2008 CLK 550 2012 C300
Hey Aceit,
Does the ticking noise vary with the engine rpm? If not, maybe it is the valve opening and closing that returns the trapped fuel vapors in the carbon canister. The name of that valve escapes me, sorry.
Thanks,
Zill.
Quick Reply: 2013 CLK350 Ticking sound
