LED license plate modules... BRIGHT! (Pics)
Old Nov 3, 2014 | 11:22 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow LED license plate modules... BRIGHT! (Pics)
So to help others since there wasn't a really clear answer on the topic when I searched. You will notice that on ebay you can find w203 led error free license plate modules. I decided I wanted to do this rather than replace the incandescent bulbs to leds because my lenses were all brown anyways, so if I bought new lenses they were $14 each, not counting the cost of the LEDS which would have been another 10 bucks... The LED modules cost $19 with free shipping, and they came from a NJ so right here in the states. The module looked just like the one I took out that came stock with a normal bulb...
Below are the results. They are so nice/clean white light and they are bright. LOVE IT.
You want the ones that look rounded, not rectangles.
They are in fact error free. Plugged right in using the same oem connector/harness on the back of the car as well.
-Nigel
Attached Thumbnails LED license plate modules... BRIGHT!  (Pics)-1.jpg   LED license plate modules... BRIGHT!  (Pics)-2.jpg   LED license plate modules... BRIGHT!  (Pics)-3.jpg   LED license plate modules... BRIGHT!  (Pics)-4.jpg
Old Nov 20, 2014 | 08:51 AM
lmal355's Avatar
clk500
did this on my old m3, how hard is install in the w209?
Old Nov 20, 2014 | 10:05 AM
Install wasn't bad. I found a thread somewhere showing that you have to remove the rear plastic piece on the trunk.
Basically you undo all the little push clips once you open your trunk, to pull the felt lining thing down. Once you do that then you will see two screws on each side, you undo those and then there is a center screw/bolt that you undo directly behind where your license plate. Once you undo all of that, you simply pull straight down on the plastic part of the trunk. That comes off and then you can completely remove/install the modules. It took me roughly 30 minutes to do by following the how to on here. It took all of 5 minutes to put everything back together. Going forward it would probably take me 10 minutes to take it all apart. It's quite easy.
Definitely worth it and so much nicer looking with all the light!
-Nigel
Old Nov 20, 2014 | 10:56 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Where did you buy these? Link?
I got some from Germany....they look very similar. I am wondering if they are the same ones or not.
Old Nov 20, 2014 | 12:01 PM
Arrow
got them off ebay.
http://www.ebay.com/itm/161286360491?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
For some reason the dude has them for $117!!? I paid 17! I think they f'ed up on the decimal point because I can't see anyone spending that much money for them at all!
Shipped from the USA I believe Jersey so I had them in only a couple days. Zero errors.
-Nigel
Old Nov 20, 2014 | 01:24 PM
megacrazy's Avatar
Cool. Yeah they seem to be the same ones I got. They were a direct fit on your car?
The stock ones have 2 clips one on each side, while these only have 1 clip and a tab on the opposite side. I had to improvise the installation a little bit. Otherwise they would have been loose.
Old Nov 20, 2014 | 01:53 PM
Patton001's Avatar
2006 CLK350
Just out of curiosity, to you have a "before" picture showing how much light the originals produced?
Old Nov 20, 2014 | 03:18 PM
megacrazy's Avatar
These are easily 2-3 times brighter than stock....Also the light is pure white.
Old Nov 20, 2014 | 05:41 PM
AMG_Adon's Avatar
05 E55
nice find
Old Mar 25, 2015 | 11:12 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
I just replaced, tonight, the license plate light modules with led ones. Dang! They are bright. I had a heck of a time getting it done. I took some pics and will make some notes on the install and post them here within the next couple days.
Recently replaced the tails and 3rd brake light also. May make a short movie clip of how they look.
Old Mar 26, 2015 | 05:38 PM
Patton001's Avatar
2006 CLK350
Its 2:00 in the morning, you just knocked over a liquor store, you are making your getaway. WHICH CAR WOULD YOU RATHER BE DRIVING?
Old Mar 26, 2015 | 05:58 PM
Still would rather have the brighter one because it looks better... anyone robbing a liquor store is an idiot anyways, more than likely there are cameras SOMEWHERE in the lot and will get your plate anyways...lol
-Nigel
Old Mar 27, 2015 | 04:58 AM
Fatz's Avatar
Install procedure used for CLK550.
Old Mar 27, 2015 | 05:01 AM
Fatz's Avatar
Here are a couple non-embedded pics.
Attached Thumbnails LED license plate modules... BRIGHT!  (Pics)-dsc03420.jpg   LED license plate modules... BRIGHT!  (Pics)-dsc03414.jpg
Old Mar 27, 2015 | 11:35 AM
Looks good! Real clean! Install procedure is right on!
-Nigel
