what is this ?
Old Jan 24, 2015 | 07:48 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Originally Posted by TheNoble
Rodney,
Is rear-side airbags not standard?? I thought was across the board on all W209 models.
I'm going to see If I have some paperwork and dealership sales records from the gentlemen I bought this car off of. Maybe that'll shed some light
It's an option, not standard. I have them as well and the dealer told me it's rare to see those, but honestly should be standard.
That thing can't be for the rear AC. How come no one else has one then? Idk weird and what's that symbol on the sticker?
Old Jan 25, 2015 | 12:07 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, rear seat side airbags are optional. I think the were standard on most all MBZ models until 2002 or so, then people began to get scared of them with kids in the back seat, so they became optional. And because it's an extra cost item that few people want, it was rare for dealers to order cars with it.
Old Jan 25, 2015 | 07:38 PM
TheNoble's Avatar
2003 CLK320
Does this help? It's the motor underneath that shell
Old Jan 25, 2015 | 09:03 PM
Yidney's Avatar
2008 CLK550 Cab
My car has every option except rear air bags. If you look at every W209 for sale on autotrader etc, you'll see that the option is so rare that you wonder if it was really offered. Maybe 1 in 100 have them.
Old Jan 25, 2015 | 09:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I can't find the part number in EPC, but that's not unusual as often the printed number on a part is not the actual part number since it is printed by the OEM. A web search pulls up a few eBay auctions and that's abut it. I am still a bit perplexed about this. I even checked some old dealer/manufacturer info I have and can't find nay mention of this being an option or a discontinued part.
Old Jan 25, 2015 | 10:15 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
Does this help? Mercedes W203 S203 Gebläsemotor Heizungsregler Lüftermotor FOND 2038300308 BEHR
https://mein-autoteil.de/es/Mercedes...0308-BEHR.html
Old Jan 26, 2015 | 01:49 AM
  #32
DanielFD's Avatar
2007 BMW 550i
we'll if its any help.. STAR mentions this blower. There is an option to enable it (if its installed obviously).
Old Jan 26, 2015 | 04:30 PM
  #33
xsever's Avatar
2012 C300 4MATIC Sport
The one eBay auction I found lists it as: "This is an OEM Mercedes-Benz C320 C-Class W203 Rear Center Console A/C-Heater Blower Motor and Fan Assembly with wired Plugs...."
Old Jan 27, 2015 | 12:43 AM
  #34
gaazmon's Avatar
there's no room in his center console. is that normal?
Old Jan 27, 2015 | 09:55 AM
  #35
TheNoble's Avatar
2003 CLK320
I had some friends in the car and we turned on the back AC vents and wow. That thing blows hard. Lowest setting on the dial is plenty but you can really crank it up. One of the guests was wearing a skirt and she had to hold it down lol.
Not sure what the application would be to need that much air flow but ya...there ya go.
That being said If I had the choice of getting such an odd add-on, I'd opt for the extra console space.
Old Jan 27, 2015 | 12:34 PM
  #36
DanielFD's Avatar
2007 BMW 550i
I had same friends in the car and we turned on the back AC vents and wow. That thing blows hard. Lowest setting on the dial is plenty but you can really crank it up. One of the guests was wearing a skirt and she had to hold it down lol.
Then we should all definitely retrofit this then!
Old Jan 27, 2015 | 03:00 PM
  #37
gaazmon's Avatar
Well then. This just made it on top of the next mods list
So is this like an optional more heavy duty blower? And does it have it's own controls (like i've seen on e500s/550s and cls500s/550s)? My AC blowing is so weak. Even on the highest setting for the front it's pretty weak. There's no real airflow until like the #6 setting. My indy recharged the AC and all and he said its fine and couldn't find any leaks either
Old Jan 27, 2015 | 11:42 PM
  #38
TheNoble's Avatar
2003 CLK320
In terms of settings I do not believe there is anything special. It is still the turning knob on the center console but in this case it basically just goes off, mild, and hurricane. The fan adjustments from the front have no effect on the back vents as they are independent because of the motor. Not as much control as the adjustment knob might make it seem like it would.
Old Dec 10, 2015 | 02:52 AM
  #39
TheNoble's Avatar
2003 CLK320
Anyone know what this is? Is there a cap to this? It is right behind the engine
I discovered it the other day while cleaning up the engine bay.
Old Dec 10, 2015 | 09:27 AM
  #40
DanielFD's Avatar
2007 BMW 550i
Thats either your oil filler cap (red) or the transmission oil filler cap (black, with opt red locking pin). I cant really tell with the picture, but they are next to each other.
  #41
DanielFD's Avatar
2007 BMW 550i
and yes it should have a cap
Old Dec 10, 2015 | 03:36 PM
  #42
TheNoble's Avatar
2003 CLK320
Based on other photos i just looked up it is the red cap that is missing. Well good to know that it is I was a bit puzzled when I saw that.
Outside of my local junkyards, anyone know where I might be able to get that piece. Don't recall seeing it on parts.com...
Is there any danger of leaving it open?
Old Dec 11, 2015 | 02:00 AM
  #43
DanielFD's Avatar
2007 BMW 550i
you can get it at the stealership, its not that expensive i think around 6$. I dont think its an issue, but if it were my car I'd like to know my engine's holes are plugged.
Old Dec 12, 2015 | 09:36 PM
  #44
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's the oil dipstick tube - you can see it without removing the engine cover. The transmission fluid dipstick tube sits lower - you'd need to remove the engine cover to see it. There is a cap/plug that should be on it. Part number is A6460100035
Old Dec 15, 2015 | 11:56 AM
  #45
TheNoble's Avatar
2003 CLK320
Great, thanks Rudeney and Daniel!
