red flash on dashboard
Old Jan 20, 2015 | 09:34 AM
Benzito K's Avatar
2007 Clk 550
After I filled up last night with premium gas from Valero Gas station while driving I saw a red flash on the dashboard and heard a beep it was to quick for me to see what it read but shortly after it felt like the car was loosing horse power. When I put my foot into the gad pedal it didn't have the usual get up and go it seems to drive ok but when i get to 80mph it dosent speed up....Please Help
Old Jan 20, 2015 | 09:42 AM
Yidney's Avatar
2008 CLK550 Cab
Go to an auto parts store and have them see if it has any stored codes. Most will read codes for free. It can have a code even of the CEL is not on.
Old Jan 20, 2015 | 09:48 AM
DanielFD's Avatar
2007 BMW 550i
you should definitely be getting some codes just like yidney said. better check that out. any vibration when the car is at idle? are the gear shifts alright i.e. smooth and normal? the only thing that can trigger a red light are an open door and a bad battery/alternator, unlocked steering column, a couple of other stuff. but nothing that's connected to the fuel pump/parts/lid; the 2 events are probably unrelated
Old Jan 20, 2015 | 10:14 AM
Benzito K's Avatar
2007 Clk 550
No problems idling it feels like the power isnt there as if i was running on 6 cylinders instead of 8
Old Jan 21, 2015 | 08:36 AM
DanielFD's Avatar
2007 BMW 550i
sounds like its either a very simple thing or a very complicated thing; better of getting codes from the ECU
Old Jan 21, 2015 | 10:14 AM
Benzito K's Avatar
2007 Clk 550
I took.it to autozone to get the codes read but they're weren't any showing up Zero.....so tomorrow morning ill take it to see if my spark plugs need changing or my coil pack is bad
Old Jan 22, 2015 | 02:00 AM
DanielFD's Avatar
2007 BMW 550i
sometimes a generic code isn't given. a thorough test on STAR from a qualified person can find a problem fast. Try and find an independent shop that has STAR and knows how to use it.
Old Jan 22, 2015 | 09:37 AM
Yidney's Avatar
2008 CLK550 Cab
Sparks plugs won't cause a sudden loss of power. A bad coil pack on one plug will cause a misfire or rough idle but not what you describe really.
Old Jan 22, 2015 | 12:09 PM
jdhiller's Avatar
2004 clk500 cab
Is it possible it was the collision avoidance warning. mine does that from time to time
Old Jan 22, 2015 | 02:10 PM
Benzito K's Avatar
2007 Clk 550
Ok guys thanks for the suggestions I intended on getting it to the shop today but got called into work. ...hadnt had any further issues I put my foot in it and its moving but it still doesn't give me that get up and go
