2004 clk convertable Stereo
Old Jan 26, 2015 | 10:36 AM
jdhiller's Avatar
2004 clk500 cab
I have a 2004 by title, I am informed that the navigation stereo is the d2b unite and not the most network unite. I would like to have a way to play music from my phone either by wire or Bluetooth to the stereo. I have no desire to use a cd changer. I purchased the Mcar unite after several aborted attempts to install they informed me that it was not going to be compatible.
I am confused doe to the fact that I have a 2004. if there is some light someone can shed on this I would appreciate it.
Old Jan 27, 2015 | 12:06 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
MY2004 has the D2b fiber optic system. mCar only works with the MOST fiber optic system which was introduced with the MY2005 "facelift".
Old Jan 27, 2015 | 02:06 AM
DanielFD's Avatar
2007 BMW 550i
your going to have to change the headunit to 3rd party, or install command 2.0 and benefit from AUX. I think if i'm not mistaken theres was some module that replaces the CD changer that works over D2B, but I've read a lot it wasn't reliable.
Old Jan 27, 2015 | 09:17 AM
jdhiller's Avatar
2004 clk500 cab
Is there a way to connect a aux cable to allow me to plug a player to it and feed to the sat radio connection on the head unit
Old Jan 27, 2015 | 09:20 AM
DanielFD's Avatar
2007 BMW 550i
can you take a picture of your headunit? just to make sure we're on the same page. or find a picture on the internet of it and post it here. make sure its the exact same one
Old Jan 27, 2015 | 12:15 PM
jdhiller's Avatar
2004 clk500 cab
Here is the photo of the dash head unit
Old Jan 27, 2015 | 12:28 PM
DanielFD's Avatar
2007 BMW 550i
Okk great!its pretty simple for you! You have what is called command 2.0. I had to retrofit command 2.0 just for aux. just follow this guide i got off the internet.
http://www.mwstewart.co.uk/w209auxin/
Old Jan 28, 2015 | 11:19 AM
jdhiller's Avatar
2004 clk500 cab
I there a way to know if I have the face lifted model, it makes a difference in which cable I buy.
Old Jan 28, 2015 | 11:23 AM
DanielFD's Avatar
2007 BMW 550i
That is correct! Big difference! But as rodney stated the facelift model which starts by MY2005 runs on the MOST System. Thats why i told you to send a pic of your headunit to make sure. If it looks exactly like that picture that you posted and not like the picture below then its the prefacelift model (D2B system)
Old Jan 28, 2015 | 11:59 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You do NOT have the facelift model. This is a MY2004 or earlier.
Old Jan 29, 2015 | 11:51 AM
jdhiller's Avatar
2004 clk500 cab
Thanks to all for the information.
Old Feb 28, 2015 | 09:28 PM
tjprescott's Avatar
2002 ML500, 2001 C240, 1993 400E
Bluetooth solution for old head units
I found an ION Bluetooth cassette tape adapter that has no wire to prevent the door from closing on your command unit. Its rechargeable and I plugged it into my 2002 ML500 and immediately paired it with my iPhone and it works great. $27 or so on ebay. I found a used one for $17. Cheap way to extend an a great old system into the future.
Old Mar 5, 2015 | 11:24 AM
jdhiller's Avatar
2004 clk500 cab
It is not equipped with a tape deck it has the cd nav. and a 6 disc changer.
