Is there any way to add bluetooth to a 2008 CLK550?
#51
Hi everyone,
I have a 2009 CLK350 Coupe and am trying to do the "cheater" bluetooth install. It was mentioned here that the installation for the cabriolet is easier than the coupe. What other parts would I need in addition to or replace the cabriolet "cheater" kit? What are the differences?
From my research, I have read the Star Bulletin for the 209 Coupe bluetooth install already, and I have read dleeme's Notes on W209 2008 CLK550 Cabriolet Bluetooth Module Install-s djl.pdf
If someone who has installed the OEM bluetooth on their coupe could provide any advice or guidance at all, that would be greatly appreciated!
#53
BRS25
Hi,
If you want proper integration to your controls, it is best to do the complete install as per my instructions.
Open the left panel and right panels in the trunk and look inside. If it’s like my pictures, everything should work providing you have the wiring.
Open your center console and remove the back lining to see if you have the puck wiring there.
Good luck.
Good luck.
#54
Hey dleeme,
thanks for the reply! For some reason I didn't get a notification in my inbox, so I missed your message. But I was able to successfully complete the factory bluetooth install using your instructions along with the star bulletin instructions on my coupe.
Details of my install are here if anyone else is interested.
https://mbworld.org/forums/clk-class...-retrofit.html
#56
Adding OEM telephone to CLK
I just bought a 2008 CLK 350 Cabriolet with Nav, Sirius, CD changer, HK audio but no phone. The car was equipped with mobile prewire (option 387 on data card.) If your car doesn't have this,forget installing an OEM system. After a lot of searching and considering aftermarket options, I found Keith Valentine in SoCal, who sold me an OEM system comprised of the phone module, phone cradle, bluetooth adapter and a couple of fuses. The phone gets installed in the fiber optic loop and the bluetooth module ends up in the tiny storage compartment between the front seats. I was concerned that I would foul up the entire system and wreck things, but Keith spent lots of time on the phone with me BEFORE I bought anything and I got comfortable with the concept doing it myself. I got the parts in 2 days at a VERY reasonable price (shipped CA to MA) and installed the system in about 2 hours, being very deliberate and careful. It worked first time and perfectly paired to my Apple SE phone, with all steering wheel controls working perfectly. The quality is great. The Bluetooth does not support music play, but there is an 1/8" phone jack in the glovebox that leads to an AUX input, so you get that with or without the phone module. I can't say enough good about Keith; he was available, took time, knows Mercedes phones inside out and offered to talk me through the install as I did it if necessary (it wasn't.) He sells kits for several chassis numbers and can be reached at 714-746-5930. I found aftermarket systems required some kind of compromise (no Sirius in a new head, no factory controls, extra wiring in the passenger compartment, depending on extremely low power FM transmitter, etc.) and I preferred the OEM system. Coupes require a bit more work, but based on the degree of difficulty I had, it'd be cinch.
#57
#58
I prefer to keep my cars absolutely stock if possible, so adding the OEM system was my choice. As far as adding it to a 2008 CLK 550, call Keith but I'd say it would be easy to do for phone, not audio streaming.
#59
CLK350 Coupe 2008
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
The easiest solution, by far, to add Bluetooth to a 2011, or earlier MB is to use CoolStream's CarPro Bluetooth adapter.
It attaches to the 30 pin Aux cord in your glove box and you stream your iPhone and even Android phone to it.
You're still able to use your steering wheel controls (limited display w/Android) and it works like a charm!
I wish that I had seen this earlier.
Here are a couple of links to help you...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
https://coolstreamrocks.com/
#60
I use a Galaxy Active 8. The steering wheel functions work fine, but for the telephone.
I am told that they will work for an iPhone, the original format for that pin connection.
Check options on your Bluetooth connection with the iPhone.
I do know that you have the option to toggle media and phone separately with Android; unsure about this option with Apple.
Remove any other Bluetooth option within your vehicle, including the Android phone (or turn off Bluetooth on that device) as you could be confusing the adapter.
Is the conversation with any call over the car's speakers? You do have the car's system set to Aux (iPhone/iPod)?
Let me know if I missed something and good luck!
-E
-E
Any tips on how to make the phone feature use the CarPro bluetooth? I purchased the Coolstream CarPro for my 2008 Mercedes CLK350. Plugged it into the 30 pin dongle in the glove box and it paired with (one at a time) my iPhone 7 and Samsung Galaxy Note 8. It streams iTunes beautifully and google will even dial phone numbers from the voice command, but it the CarPro sound through the speakers cuts off instantly once the phone numbers are entered and it rings. No phone conversation at all on either phone. iPhone screen lights up to give the option of CarPro bluetooth, but nothing happens when I select it. No optional screen to select bluetooth on Galaxy Note 8. Steering wheel controls do not work over CarPro. Siri and Google voice command, respectively, will respond to voice commands for navigation from the phones and that's all it will do. Can't get a reply from Coolstream on how to make phone calls or receive phone calls over the CarPro bluetooth. It's there, but Command seems to block it. No bluetooth hook up in my center console, just a cup holder. There are phone keys on the steering wheel. A $29 bluetooth cigarette lighter charger by ROAV will play music, google talk and make and receive phone calls over the stereo system, however. Not near the quality sound of the CarPro for streaming or what I imagine phone call could be on it if it worked for that.
#61
MBworld Guru
There are fairly complex issues as to why the Carpro won't work with the car's hands-free phone controls. Basically, the phone functions of the car have nothing to do with iPod interface that the Carpro connects to. The OE iPod interface does two things. One, it routes audio through the radio's analog AUX input. And two, it takes advantage of the "open architecture" of the instrument cluster's screen to display track and title information and respond to the steering wheel up/down buttons. The Carpro simply talks Bluetooth to your streaming audio device and translates it to iPod 30-pin signals. Notice that I keep stating "iPod" and not "iPhone". That is because the interfaces (both the car's 30-pin and the Carpro) are for an IPOD to play music and have no phone capabilities.
#63
