First bug 2006 clk 500
Ok short story, abs light, check engine light, esp malfunction message, brake wear message ( their is no brake wear) the mileage is not recording and the speedometer is not working.....all this happens at once, any ideas and approximate cost of repair? The car drives fine, it's just annoying
MBworld Guru
Let's start with something simple - check the vehicle battery voltage: 12.6v at rest, no less than 11v during cranking, and 14v at idle. If you get significantly less than that, then I;d lok at battery and/or alternator issues.
06 CLK500 & 14 GL450
