2004 CLK320 front A/C blower not working.
About a yr ago a loud "clicking" sound could be heard (and felt) from beneath the pilots side dash at about once a one second interval and lasting for about a min after turning off the ignition. This has been intermittant. My mech sugested it was a duct/vent door servo, however the A/C-Heater blower was still working as long as I turned it off before shutting the engine off.
So last week the front blower finally failed yet the rear fan still worked and made cold or hot air as selected. I replaced the resistor, no help. The original blower motor (made by Behr) showed evidence the brushes were gone (car has 140K on it) so I replaced it w/ a TYC brand (#700190 oem # 203 820 25 14) from Amazon (so it must be Chinese
and still no help. I did a bit more reading within the forums and then tried an "ACC" reset by holding the defrost & recirc buttons together . . . I got the continous alternating lights and heard the same "clicking" beneath the dash coming from more than one location . . . still no help . . . I miss my A/C
Anyone ?
As for the blower, it's possible that your replacement parts are bad. Did you try bench testing them?
Yes it's possible the new blower is "bad from stock" and I'm going to pull it again to check operation on 12v. But even more telling may be to see if there's power to the plug. The old blower had no brushes left on the commutator so I thought replacing the blower assy would solve this. I'm tempted to just replace the brushes in the old blower motor if im getting power to the plug comming out of the chassis.
Of coarse I did ohm out the two fuses shown tied to the A/C-Heater blower and they checked good. One is in the cabin @ 15A, the other is in the engine comp @ 7.5A. I think I'll just replace those anyways, just because they ohm out OK doesn’t mean they will carry current.
I'd sure like to find a diagram showing what all the relays under the hood and trunk are for. I suspect there's more to this blower control than a resistor and two fuses.
bw
http://benzbits.com/w203/fuses.html
Thank You for the relay diagram intel, I'm sure it will pay off as iintsnd to keep this car ! : )
bw
