CLK 500 black series body kit project
When I start it and set off on a cold morning, in second gear, when I lift off, I get some really nice pops, but it stops happening after a few minutes
if I wanted it to be doing that a bit more often, would the best bet be removing the cats and then possibly tuning the map to overrun the injectors?
im sure it looks much much better in person. not feelin' the wheels but. doesnt compliment the BS kit really well. maybe you need something more aggressive design wise (wheels) and needs to lower a bit more. thats just me though. sounds amazing!!!
Reducing the restrictions more by removing (I assume) the secondary cats will have the explosion happen farther downstream because the exhaust is moving faster; they will be louder since they are not muffled by the secondary cats and resonator and they happen closer to the exit.
Those pops probably have always been there, even with the OE tune. The sound is diminished greatly after traveling through the secondary cats, resonator, and muffler, as well as crashing into slow moving exhaust gases. I would not remap unless it was part of an ECU tune.
A dyno, long after the changes, yielded a 306-308 HP at the wheels if memory serves me correctly. And again from memory a stock 550 is about 267 HP at the wheels.
I think the issue may be with space for the 500. Although when I look at the cats they are not much bigger than the pipes (probably 3.5 - 4.0 inches in diameter).
I recall there is someone on the forum with a 500 and Kleeman SC. They may be able to shed some light on the cat issue/solution for the 500. Also, I think Kleeman is a sponsor on this forum.
will have a search now, update, wrapped the side fins of the front bumper today.
