technical
Old Sep 13, 2015 | 03:46 PM
hancockers24's Avatar
clk550
technical
New to MB world hope someone can give me some tech support.
Old Sep 13, 2015 | 03:54 PM
clk550
tech
My wife's 2009 CLK550 has been in the shop since June to replace the hydraulic pump. Put the pump in ($2700.00) did not fix the problem. Put new hoses on ($400.00) did not fix. rebuilt the cylinders or rams did not fix. The system stops working when it starts to lift the window and the case cover.
3 months in the shop need help.
Old Sep 13, 2015 | 06:32 PM
dbldpr's Avatar
Veteran: Navy
Welcome What type of shop did you bring it to?
Old Sep 14, 2015 | 10:28 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W209 forum...
u should have the shop put old pump and hoses back, get full refund and find a better shop...
Old Sep 14, 2015 | 05:27 PM
clk550
I took to the shop I bought the car from. I have had the car about a year. The shop deals mostly in imports.
Old Sep 15, 2015 | 06:02 AM
Gary C's Avatar
2004 CLK 500
Sounds like a limit switch is the culprit.
Old Sep 16, 2015 | 07:52 PM
clk550
technical
Thanks for the info, would you happen to know which one.
Old Sep 16, 2015 | 10:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's hard to say which limit switch might be the problem without getting the codes from the top controller module. If your shop does not have SDS or another proper scan tool that can read these codes, I'd find one that does. Otherwise, you'll keep spending money by throwing parts at it.
