Convertible won't finish closing
With low hydraulic fluid in the pump, what are my new expectation?
Prior to opening the trunk, i manually lift the lid up. Then i took out canvas top and attached it to the front, then i slide the compartment cover all the way in, unaware that rear windshield needs to snapping on the cover first, then i can slide the cover in. Now i can't lift the cover out.
PS. no noise or function from the pump when i press the control switch.
Well, that could be a hint, here. If you have low fluid, this may not be a limit switch issue - you might have a leak. When you try top operate the top with the console switch, does the pump run? If so, then I;d look more toward a leak being the issue.
After my last reply to you, These were my list of actions that roundup this Saturday evening.
1. Filled the reservoir to the max.
2. Turn the valve on pump 45* to left, turn valve on both side struts to 90* to left.
3. Noticed the the fluid leveled dropped to between max and mini line.
4. Failed at lifting and pulling the compartment hinges.
5. Reversed step 2.
6. Got in the car and engage the switch, no sound or action from system/pump.
7. Shift the transmission from to to park to drive back to park.
8. Engage the switch once more and windows goes up and compartment cover lifts and slide backwards to engage the rear windshield bow.
9. Got out of the car to inspect and then completed the closing process.
10. Fluid level dropped below the mini line and fluid was added back to max level.
(never added fluid in 31 months, last time i checked it was a mini line/level.)
Thanks the demigod Rudney and Lord Balarama(Krishna's merciful older brother)
When you have the time, can you share your thoughts on what i need to prepare for from here on forward.
Hari Bol
Respectfully
Arjuna
Hari Bol
Here's the WIS doc for removal:
http://benzbits.com/w209/soft_top/MainLiftCylinder.pdf
You have to remove the rear seat and rear paneling:
http://benzbits.com/w209/RemoveBackSeat.pdf
http://benzbits.com/w209/RemoveSidePanelling.pdf
I read the following thread which seemed to describe my problem exactly but was unable to find any fault with the front windshield switches.
https://mbworld.org/forums/sl-class-...indshield.html
Thanks Jeff R.
Respectfully and valued
Arjuna
Good information and replacement Seal Kits located at the following:
Seal Kit: http://mbseals.com
Instruction for Rebuild: http://mbseals.com/R129TopCylindersRnRall.pdf
As for your comments on the Detached/faulty switch and direction on to what switch that could be? Before I started the rebuild all the switches worked.
All the Best.
Jeff R
The problem is very consistent and very reproducable. I can go back to the open position, but can not complete the closing. The top was working fine before it. The fluid level is good, no leaks anywhere.
Any suggestions for the next step? I'm guessing it's some other limit switch, but which one and where? Thanks!!!!
But if anyone has had a similar problem and knows the likely reason and the fix it would be great! Thanks!
After having a few failures in different cars recently caused by different clueless certified mechanics (broken suspension link due to left-right links mixed up, loose brake caliper bolts ending with a big "bang" when a loose bolt went flying when driving away etc) I begin to loose faith in that profession...
If I keep pressing the top button, the pump keeps working but nothing happens. If I wait several seconds and press the top button again to close, the top finishing closing properly.
What could be the reason? Has anyone got an exact sequence of the top operation which lists exactly which switch closure triggers which piston to operate next? I've checked most of the switches (7 or 8) and they operate correctly. But maybe they are slightly loose sometimes and don't work in all cases?
Or is the pump weak? At which point of the top operation is the highest pressure required? How to measure if the pressure is good enough? The shop which was doing all the poor top repairs before for the previous owner also installed a used pump charging $1000 for the part (instead of rebuilding it for $600 at TopHydraulics or charging a fair market price of $300 or so), so I'm not sure how good the pump is.
thanks!
http://benzbits.com/w209/soft_top/W2...gnosticAid.pdf
1) Print Rodney's document from benzbits above (thanks Rodney)
2) Connect DAS, set it on display of all the "actual values"
3) Operate the top through Stages, see what documented Stage it stops at and see the values of switches at that point
In my case it completes stage 4 correctly (Switch S84/15 shows the bow is in fully raised position), fails at stage 5 (cylinder 2 fails to lock roof into the windshield), and does not start Stage 6 (closing the compartment).
So next I need to figure out why cylinder 2 fails to lock (no leaks at this cylinder). Thoughts? thanks
I don't see any problems with the switches - S84/18 registers that the soft top reaches the windshield and S84/15 registers that the bow is fully open.
Once I lock it manually and I want to open the top, the cylinder unlocks ok (hydraulics work fine to unlock) and the top folds down nicely.
Now I'm 100% sure the problem is hydraulics - if I "help" the cylinder to lock with a wrench, it locks correctly and the cycle completes correctly.
Can the top lock cylinder fail in a way that it does not e lock by itself, but unlocks smoothly? Or is it a weak pump?
Thanks!!!
