How to route a wire from trunk to dashboard ?
When I did this some time ago, I only had to raise the rear seat bottom and find where OE wires are coming from the trunk.
You can now deviate from the OE wire path and run your wires under the plastic molding overlapping the carpet.
This will get you to the foot wells under the dash. Since my project terminated under the steering wheel that is as far as I've gone.
I can't help you on getting into the dash.
You can buy a 3-4 ft rod used for fishing wires between finished walls. Run the rod along the OE wire path. Tie/tape your wires to the end and just pull the wires through from the trunk to the cabin area.
