Altitude pressure sensor signal -short circuit to ground
Old Oct 21, 2017 | 03:45 AM
georgeclk200's Avatar
clk200
Exclamation Altitude pressure sensor signal -short circuit to ground
Hi everyone, I had my CLK to the garage to replace some ventilation valve hose, and when I got the car back the engine light went on, my diagnostic says "Altitude pressure sensor signal - short circuit to ground". Does anyone know what that sensor is and where is it located? What does short circuit to ground might mean?
Thank you very much
Old Oct 21, 2017 | 12:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
What is the actual code you pulled? I can look that up in SDS to see what possible diagnostic steps it guides us to.
Old Oct 21, 2017 | 01:20 PM
clk200
Hello! Thank you for your reply, I am using a delphi diagnostic, the fault code I get is 2013. (DTC 2013).
Thank you
Old Oct 21, 2017 | 08:47 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's either a bad sensor or a wiring problem. Here's the sensor:
Old Oct 22, 2017 | 03:43 AM
clk200
thanks you very much for your help I really appreciate it!
Do you also happen to know what is the attached in the green circle? I havent seen those connected for over a year and I knew I was missing something there..
Old Oct 22, 2017 | 12:56 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, I don't know where that goes. Maybe another forum member with an M271 engine can look and see? In fact, you might want to pose the question in the W203 forum as there are many more M271 engines in that model.
Old Oct 23, 2017 | 04:21 PM
Russell Ormerod's Avatar
not a merc
Most likely vacuum supply for headlamp range adjustment
Old Aug 25, 2019 | 06:35 PM
Casmige's Avatar
2006 C230 AMG Sport Sedan, 2003 C230 Kompressor Coupe
Hey there!,
Thanks heaps for your post & helpful reply.
It helped me solve a serious Short to Ground P0105 CEL Code in my Daughters 2003 C230 Kompressor.
Although?? What you have circled?? is not the Altitude Pressure switch.....The Sensor though that is right above your Red-Square circled item is indeed in fact the Altitude sensor.
Here's where it gets sorta confusing though:
Mercedes Benz OEM part number for this Sensor (What MB calls the FORE Manifold Pressure Sensor) is the same part & part number as the "AFT" Manifold Pressure Sensor....what actually installs into the manifold at the back underneath the wiring harness for the ECM.
The Front one does in fact measure barometric Altitude pressure....& in my daughters case?? Someone previously had hooked up the Vacuum hose that normally would go to the Headlight Wiper Servo's mistakenly.
Your post got me thinking about WHY MB would call the front the "Altitude Pressure Sensor" while the rear one (Same part, Same part number) the Manifold pressure sensor.
It would ALSO explain WHY MB has the Front sensor hiding itself in a little bit of a cave that, if one hooks a vacuum hose to?? would crimp & cramp it once you screw down the sensor).
Which translated all this issue in my case?? to simple disconnecting the Vacuum hose, plugging it with a screw & leaving the FRONT Altitude Pressure Sensor without any sort of hose attached to it.
VOILA!! the CEL never came back on for the P0105 Pressure sensor Short-to-Ground Fault code.
Your post along with this thread though helped me muse & over-think the issue to a rather neat Socratic conclusion!.
Thank you!
