Convertible sensor in trunk
Old Dec 9, 2015 | 09:44 PM
BK627's Avatar
2007 CLK 350 Cab
2007 clk350 convertible
My top works fine but I have the sensor in the trunk pushed down with a zip tie because something has to be missing. Nothing seems to be broken off the cargo cover. I'm attaching a picture of the sensor in the back.
Old Dec 10, 2015 | 09:33 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I believe the gas struts on the trunk partition have failed. Over time, they get weak and won;t hold the partition closed tightly enough to trip this switch. Replace those struts and you'll be back in business. With new struts, they will be very strong and it will take a good bit of pressure to operate the partition. I bought mine from RMeuropean.com - $21 each.
Old Dec 10, 2015 | 09:43 PM
BK627's Avatar
2007 CLK 350 Cab
I changed the struts. I bought the car like this. There's too big of a gap from the cargo cover and the switch. There might be a piece missing or something is broken can someone take a picture of theirs so I can compare
Old Dec 11, 2015 | 01:12 AM
Yidney's Avatar
2008 CLK550 Cab
I'll post a high res pic of mine tomorrow. Yours does look odd, but I cant't say why because I have not looked at mine in a while.
Old Dec 11, 2015 | 09:56 AM
Yidney's Avatar
2008 CLK550 Cab
Here's a pic of mine, but as you can see it won't do you any good because it looks exactly the same as yours. Maybe your new gas struts are bad, or the partition has some issue. Is your partition off to one side? They can get bumped and be off center. Maybe yours is just not contacting the switch right? The switch should give an audible click when you press it in just a little.
Old Dec 11, 2015 | 10:00 AM
Yidney's Avatar
2008 CLK550 Cab
Anyway, if you need pics of how the partition contacts the switch, let me know.
Old Dec 11, 2015 | 12:23 PM
BK627's Avatar
2007 CLK 350 Cab
Here is a picture of mine closed you can see how off it is. Maybe I'm missing a piece I'm not sure. If you can send me a picture of yours closed just so I can see.
Old Dec 11, 2015 | 01:25 PM
Yidney's Avatar
2008 CLK550 Cab
I'll post up a pic. Your pic is not the best quality, but I don't think you are missing anything. That little post on the partition is supposed to press the switch. But yours looks like it's about an inch too far right. So one of two things is true - your partition is too far right or the switch got pushed left. I tend to think your switch got pushed left for two reasons. One, it has scrapes on it like it's been hit. Two, I don't think the design allows the partition to be that far right. Dead center in your partition above where the handhold is there is a plastic centering arm. It goes into a hole when the partition is lowered. If your partition is off center even a little bit that arm will rub. I had to re-center mine like 1/8". I don't think the partition could be off as far as yours is. But it may also not be possible for the switch to get pushed that far left. So you are going to have to investigate the cause, but physical alignment of the two parts appears to be your problem. Neither should be a hard fix.
Old Dec 11, 2015 | 07:07 PM
Yidney's Avatar
2008 CLK550 Cab
Here are some photos of mine. The key thing is that despite the closer gap, notice how the switch on mine is perfectly parallel to the edge of the partition. Yours appears to me much farther away at the bottom - in other words, bent. Upon closer inspection, the switch is mounted on a metal strap covered in plastic (see other two pics). It could easily be bent in. If it it were me, I'd remove it and remove the plastic to straighten the strap, but you might just be able to grab it and slowly bend it back. But open your back panel to see it better from above and see exactly why it's crooked.
Old Dec 12, 2015 | 10:54 AM
Jackharja's Avatar
2009 MB CLK 350
Just bought this 2009 gal yesterday knowing there was an issue with the trunk partition cover. It was missing the gas springs and has a "fix" on the top switch. When I looked further after reading this blog, I noticed the right side bracket appears to be severely bent. See photo. Can I bend this back and should the socket ball be in a horizontal position? I can't accurately compare to left side as that may be bent also.
Last edited by Jackharja; Dec 12, 2015 at 10:59 AM. Reason: intended picture did not attach.
Old Dec 12, 2015 | 11:28 AM
Jackharja's Avatar
2009 MB CLK 350
Picture added (finally)
Should have checked the FAQ's first. Quick reply does not work for pics.
Old Dec 12, 2015 | 12:08 PM
BK627's Avatar
2007 CLK 350 Cab
Mine was also bent and I had to straighten it out. But mine wasn't as bent as yours. Pretty much straightened it out with some pliers.
Old Dec 12, 2015 | 12:37 PM
Yidney's Avatar
2008 CLK550 Cab
The things people do to their cars - how does that even get bent like that? But yeah, it's just sheet metal - you can massage it back into shape. Yes, the ball ought to be horizontal. Despite how badly it is bent, you can pretty much see how it should be.
Old Dec 14, 2015 | 10:35 AM
Jackharja's Avatar
2009 MB CLK 350
Thumbs up next stop - sheet metal bending
Thanks for the advice. I was really stumped as to the positioning of this strut post. The gentleman I bought the car from is 88 years old and could not recall how this happened. Go figure!
Old Dec 19, 2015 | 08:52 AM
BK627's Avatar
2007 CLK 350 Cab
You were right it was bent. I just grabbed it and bent it back into place and now everything is working fine. THANKS AGAIN!
Old Aug 10, 2017 | 11:47 PM
j3leung's Avatar
The cover is not locked with the sensor
Hi guys, sorry to resurrect the thread. I have a similar problem. The convertible soft top works fine but I have to depress the sensor manually as the cover doesn't lock itself in place.
I read this thread and not sure what you guys meant by bending the metal? Am I missing a piece to lock in the cover? It seems like no matterm how hard I tried to pull it down... the sensor still jump back out.
view from the bottom
The part that sticks out is quite narrow and cant really hold it with the sensor part that seems larger fitting
Old Aug 10, 2017 | 11:52 PM
j3leung's Avatar
yes the gap is too big... is exactly my problem as well
Old Aug 11, 2017 | 12:22 AM
Yidney's Avatar
2008 CLK550 Cab
Your pictures are not really clear enough. You might just have bad gas struts. If you can pull the partition down manually and the little plastic post presses the switch, then you need new struts.
Old Aug 11, 2017 | 01:29 AM
j3leung's Avatar
thanks, I think replacement of the new struts is what the other thread is talking about? Do you know what is the approx cost to order for the dealer and is it easy to install?
Old Aug 11, 2017 | 08:26 AM
Yidney's Avatar
2008 CLK550 Cab
Don't order from a dealer. Buy them online from a place like Pelican Parts. Buy Stabilus brand, not the ones with MB on them because Stabilus makes them anyway. They are less than $20 each. Very easy to install if you have any skill at all.
Old Aug 11, 2017 | 02:28 PM
PelicanParts.com's Avatar
SPONSOR
I am here to help if anyone ever needs anything!
Old Aug 13, 2017 | 11:58 PM
j3leung's Avatar
I guess thIs is what I need?
Old Aug 14, 2017 | 12:00 AM
j3leung's Avatar
Thanks! I think you guys offer shipping in USA only. I'm in Canada so what is the standard shipping charge and when will I get the items?
Old Aug 14, 2017 | 10:37 AM
SPONSOR
Once you add the item to your cart and put in your shipping address it will calculate shipping to your location. We ship worldwide, but are currently looking and working hard to improve our shipping costs to our Canadian customers.
Old Aug 14, 2017 | 11:28 PM
Yidney's Avatar
2008 CLK550 Cab
That's it.
