Tele Aid Fault
Old Dec 17, 2015 | 12:09 PM
irokdastar's Avatar
2004 CLK 500
Tele Aid Fault
If I remove the oem audio system headunit amp etc. Will I get a tele aid fault code? I do not have a telephone cradle built in my car but I do have a telephone button on my radio . Thank you
Old Dec 17, 2015 | 10:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No. This will not cause TeleAid faults, though it will mean TeleAid will no longer be functional.
Old Dec 17, 2015 | 11:05 PM
irokdastar's Avatar
2004 CLK 500
because i took out the radio to test my new head unit to make sure it turn on . and when i turned the car on i got srs fault code . I then shut off the car and put the oem radio in and the srs fault went away .
Old Dec 18, 2015 | 09:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
When you went to test the new head unit, did you have the upper control panel, with the "Passenger Airbag Disabled" indicator unplugged? If so, that's what caused the SRS error.
Old Dec 21, 2015 | 10:37 PM
irokdastar's Avatar
2004 CLK 500
Yes I did . I am guessing that was the issue . Thank you
