Grinding sound on front left wheel... not brakes?
Anyway, about every other 20 minutes of actual driving I will brake and hear a GRINDING sound that sounds exactly like I am grinding down a brake caliper.
Took it to the dealer three times. They heard the sound only once on a test drive. It is not the brakes. Plenty of pad left on the brakes.
What is this noise? It sounds related to the brakes. It only happened after the tires were changed.
Not sure what to do! Dealer says it could be a suspension spring?
nothing to do with the brakes whatsoever. lug bolts dont even touch the brake pads or the discs itself.
Very strange.
get the car off the ground and remove the tire and see if you can see anything, spin the tire and listen for it, also get someone in the car and repeat with putting slight pressure on brake and turning the steering
