Windshield Replacement
Old Jan 8, 2016 | 10:20 PM
mis3's Avatar
2004 CLK320
I have to replace my windshield and probably go with aftermarket this time. Is there any brand(s) I should avoid?
I went to an auto windshield place and he gave me 2 choices of urethane adhesives. One is MB and the other one is Betaseal 418-HV. He would charge me $40 more for the MB urethane. He said the Betaseal is as good or maybe better than the MB. Not sure if I believe this.
Old Jan 9, 2016 | 09:11 AM
Yidney's Avatar
2008 CLK550 Cab
He ought to know what adhesives are good - it's his business to know that. Unless somebody has glass shop experience, it would probably be a rare forum member that has an educated opinion on windshield adhesives. Any windshield has to meet DOT standards, so I don't know that any particular brand is bad. But do pay attention to color - not just of the sun screen band but of the glass itself if that sort thing matters to you. If you stick a sheet of white paper outside with you inside, or vice versa, you'll see the glass is not actually clear. Some are green and some are blue.
Old Jan 9, 2016 | 10:02 AM
mis3's Avatar
2004 CLK320
I agree. Urethane adhesive brand is way too specific to ask in this forum.
Is the color of the glass important since all my other glass panels are all tinted?
Actually, I am kind of discouraged of my windshield. I owe this w209 for 11 years and this will be my 4th time to change it.
Old Jan 9, 2016 | 10:05 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
My advice is to get good glass. I had Safelite replace the front windshield on my CLK about 3 years ago. They used Chinese glass and it's not held up well at all; it is covered with pits and scratches. When the sun hits it, it's like a Swarovski ornament. Pilkington used to be the OEM for MBZ. I'd get their glass or a comparable brand name not made in China. Some glass shops will agree to use genuine MBZ glass, even with an insurance claim, if you claim you've had issues with the rain and light sensors with other brand glass.
Old Jan 10, 2016 | 05:01 PM
mis3's Avatar
2004 CLK320
I just checked and my current windshield is Sekurit. I was told this was OEM windshield, not sure if this is true. This windshield is 2-3 years old and it's also full of pits but no scratch.
I called the dealership, it will cost close to $1,000CAN to replace the windshield there. The parts are $540CAN for the windshield and $60CAN for the urethane.
I was quoted $400 from an outside auto glass store. I asked for the brand of the windshield and am still waiting for an answer. I may go for the cheap route because like I said before, it seems that I have to change the windshield every 2-3 years. This is a daily commute mostly on highways so stone chips are not avoidable......
Old Jan 11, 2016 | 09:06 PM
mis3's Avatar
2004 CLK320
Got an response from the auto glass store:
1. Sekurit $425CAN
2. FY. $375CAN
I read the FY is OE for some Asian car manufacturers and they are the better Chinese brand. Based on Rudeney experience, I am now leaning to Sekurit.
For the past 3 windshield changes, I use the same trims (top, left and right) around the windshield. Should I buy new ones?
Thanks.
Old Jan 12, 2016 | 09:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Unless the outer trim pieces break, there is no need to replace.
Old Jan 12, 2016 | 09:49 PM
mis3's Avatar
2004 CLK320
The cap on the top left trim is loose. It probably comes with the trim. Do you happen to part number? I went to parts.com and found windshield trims only for the convertible.
Old Jan 12, 2016 | 10:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I've checked EPC and can't find the part number. I think that rubber cap comes with the trim, though.
Old Jan 12, 2016 | 10:46 PM
mis3's Avatar
2004 CLK320
I thought so. I was actually asking for the part number of the passenger side windshield side trim.
Old Jan 13, 2016 | 09:55 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I can't even find that trim piece in EPC at all! I am usually pretty good at finding these parts, but that one escapes me.
Old Jan 13, 2016 | 10:18 PM
mis3's Avatar
2004 CLK320
I am looking for a sticker with MB sigature.
I went to my dealers and he told me they are now very strict. No sticker if not windshield.
I may have to buy from eBay.
Old Jan 14, 2016 | 10:48 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just remove the sticker from your existing glass. Heat the glass with a hair dryer and it will peel tight off (use a razor blade to get it started).
Old Jan 14, 2016 | 11:42 PM
mis3's Avatar
2004 CLK320
I will try to finagle one from the dealership. Otherwise, I will buy one from OEDISCOUNTPARTS.
Old Feb 11, 2016 | 06:40 PM
CLK350_ATX's Avatar
2009 CLK 350 Grand Edition
what does the sticker do?
Old Feb 11, 2016 | 06:45 PM
Yidney's Avatar
2008 CLK550 Cab
It doesn't do anything. It's just a little clear vinyl sticker with a white script signature - Renaldo Benz or whatever his name was. Personally I don't like stickers in my windshield, so even when I got a genuine MB windshield i told them to leave it off. It was like $4 extra.
Old Feb 11, 2016 | 06:59 PM
CLK350_ATX's Avatar
so I'll be fine without the sticker if I'll need to replace the windshield not from the MB dealership...
Old Feb 12, 2016 | 11:19 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Renaldo? Really? Yidney, we are revoking your driving privileges! You need to sell the CLK and get yourself a Hyundai!
There are two versions of the sticker. The older sold white sticker has Gottlieb Daimler's signature. The newer clear sticker has "Mercedes-Benz" in script. Personally, I prefer Mr. Daimler's signature.
Old Feb 13, 2016 | 09:14 AM
Yidney's Avatar
2008 CLK550 Cab
[QUOTE=Rudeney;6706354] Renaldo? Really? Yidney, we are revoking your driving privileges! You need to sell the CLK and get yourself a Hyundai!
I was just making a joke. I know it was Groucho Benz.
Old Feb 13, 2016 | 11:46 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Now had you said Julie Benz...
Old Feb 19, 2016 | 05:08 PM
CLK350_ATX's Avatar
Have you got your windshield replaced? I'm curious what's the total cost and which brand did you end up using... Just got a used 2009 CLK, but the windshield is full of scratches... thinking about to replace it.
Old Feb 20, 2016 | 01:11 AM
mis3's Avatar
2004 CLK320
I chose Sekurit which is supposed to be OE. I paid $425CAN for the job which is very reasonable. I also checked the price of the dealership, windshield was $540CAN and the urethane was $60. With labour and tax, the job would cost $1,200 CAN.
The installer did a perfect job. As promised, they left my car inside a heated garage for a few hours so the urethane adhesive could cure.
Old Feb 20, 2016 | 05:30 AM
CLK350_ATX's Avatar
Thanks for the info. I quoted a local shop can do it for $350USD compared to the dealer price at $690...
Old Feb 20, 2016 | 10:26 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Most dealers don't do windshield replacements themselves. They stock the glass, but they usually have a 3rd party company come and do the work. When replacing a windshield, the best thing is to do it on a dry, warm day (above 60F) and leave it parked for at least 4 hours after to let the urethane cure.
Old Feb 20, 2016 | 11:27 AM
mis3's Avatar
2004 CLK320
Agreed. This is why I insisted that after the windshield replacement, they left my car in a heated garage for a few hours.
Back in December, I saw someone near my house replaced the windshield of a Toyota on an outside driveway. I passed by after an hour and the Toyota was gone. It was a typical winter December, maybe -10C. There was probably not enough time for the glue to cure.
