be carefull
Old Feb 24, 2004 | 05:47 AM
pakka's Avatar
clk 200 2002 (w209)
be carefull
I had an indication last night that makes me very nervous. I was parked my car and locked normaly with the key. When I finice my job i was trying to unlock the car. The indicator in the key was light normaly but the car was not respond. I press the button many times without any diferense. Finally I unlock the car with the small key wich is integrate it on the normal one, the alarm offcourse starts working untill the time I put the key on the engine slot. Then the alarm was stopoed and the car works normaly. The next day I call the dealer and he told me that probably someone was trying to block or to read the codes from my key with a devise, and there is no way to prevent this. is there someone knows something about that??
Old Feb 25, 2004 | 12:02 PM
Stiggs's Avatar
2003 CLK55
I thought I read somewhere that if the key code gets messed up it has to be reset, which it does when you place it in the ignition. Am I day dreaming here? Doesn't the engine sync with the key when inserted into the ignition?
Who are these high tech thieves out there trying to steal your code??
