Problem with negative camber
Before coilovers (rear camber only)
2014
Left -1.45 Right -1.50
2015
Left -1.30 Right -1.40
After coilovers (today)
Left -1.32 Right -2.11
So I lowered the car which to my knowledge should increase negative camber slightly and the left stayed the same (not unexpected since it is so mild a drop) but the right increased an enormous amount.
What is the correct spec for our cars? Each report is different, -0.77 to -1.77, -1.0 to -2.0, -0.57 +/- 0.5.
What should I check? There is no accident etc that could explain a bend in the pretty thick lower control arms. I guess the bushes in that arm could well be toast.
I will get another report first thing tomorrow to confirm. There are certainly ways around the legal aspects, ie if I go back to one of the earlier shops and get the report with -1.0 to -2.0 it can legally be up to 0.5 more negative camber than "stock". Of course I would like to inspect and confirm it is safe and nothing needs replacing too. Thanks for any advice.
I might just have to get some new lower and upper arms. I can't justify spending what kmac want for the adjustable bushings. I must have ruined the rubber trying to reinsert the bolts. It would have to be fairly dry/cracked/perished by this age and I may have helped it disintegrate a little on the one side.
I see the bushes are available separately but I don't have a press so might have to pay the mercedes tax for the whole arms.
Those links look good. i've seen them but personally never used them.
This pic is the ones i have on my car and sell, they are $249. Do you have xenon headlights?
Those arms look good. They look very similar to mine. I've seen some that look cheaply made for $150, but i would avoid them
I tried to find an annotated diagram on the internet and gave up trawling through WIS. Would you mind please telling me what the various links are called.
http://www.driveoemautoparts.com/aut...uspension-scat
http://benzbits.com/w203/RearSuspensionDiagram.pdf
http://benzbits.com/w203/RearSuspensionPartsList.pdf
I decided to go with the same top speed ones. They look like they have heim joints but hopefully the rubber boot will keep crap out and stop them degrading and then squeaking. I found some pictures on here of what the mb arts ones look like after one year, dreadful and top speed have excellent communication. They confirmed solid steel construction so perfect for daily driving through potholes.
