DIY camber kit
Old Mar 29, 2016 | 04:57 PM
Hoserbenzo's Avatar
08 CLK 350 sport, 11 BMW 328i, 99 Dodge Ram 1500 4x4, 06 Suzuki DRZ400SM
DIY camber kit
Is it just me or my ride got a little stiffer when I installed it.
Old Mar 29, 2016 | 08:26 PM
DRACO's Avatar
85 911 Targa
Did you put more negative camber?
Old Mar 29, 2016 | 08:36 PM
Hoserbenzo's Avatar
No. I'm still on the positive. I'll check the allignment sheet when I get home.
Old Mar 29, 2016 | 09:08 PM
DRACO's Avatar
85 911 Targa
Hmm, that does sound strange.
I put factory Camber and Caster kit, to take out the excessive Neg Camber and fix the dreaded off Caster built into our cars.
It did not change my car's ride.
Old Mar 29, 2016 | 09:39 PM
Hoserbenzo's Avatar
I'm not on the positive. My RR camber is -1.1, LR is -1.0. Maybe I should put some more white lithium grease on it. I also got new tires.
Old Mar 29, 2016 | 09:41 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
what did you use to make the camber adjustable?
Old Mar 29, 2016 | 10:04 PM
Hoserbenzo's Avatar
This is what I installed. Name:  image.jpeg
Old Mar 29, 2016 | 10:49 PM
gixxerboy's Avatar
did you switch brand tires to something with maybe a stiffer design, have you check the air pressure in the tires?
Old Mar 29, 2016 | 11:45 PM
Hoserbenzo's Avatar
I replaced it with the same size and brand tires. It's just weird that it feels stiffer. I also checked the air. When it was replaced, they put 41 psi. I dropped it to 32.
Old Mar 30, 2016 | 12:29 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
I did the same mod a couple of years back.
The wheels stay more perpendicular than with the stock design.
Of course even running 41 PSI on pillows would give a rocking ride
Old Mar 30, 2016 | 03:20 PM
DRACO's Avatar
85 911 Targa
OP so is she better now?
Old Mar 30, 2016 | 05:57 PM
gixxerboy's Avatar
probably the 40+ psi in the tires
Old Mar 30, 2016 | 06:27 PM
Hoserbenzo's Avatar
No. I changed the psi before I started this thread. I'm waiting for wheel locks. When it comes in, going to pull the wheels and put more lube on the camber kit and see if it helps.
Old Mar 30, 2016 | 08:09 PM
gixxerboy's Avatar
the lube just stops the polyurethane bushing from squeaking.
Old Mar 30, 2016 | 10:33 PM
Hoserbenzo's Avatar
Hmm. If that's the case, maybe I should just change the springs to eibach.
Old Mar 30, 2016 | 10:35 PM
gixxerboy's Avatar
you changed the springs to? I thought you just did camber kit and tires. What suspension are you running?
Old Mar 30, 2016 | 10:44 PM
Hoserbenzo's Avatar
I'm running stock suspension. What I was trying to say is that maybe I should just lower my car if my suspension is this stiff. I was thinking of putting lube on the camber kit because I assumed the camber kit moves with the suspension. It should, right?
Old Mar 30, 2016 | 11:46 PM
gixxerboy's Avatar
they pivot a little. Are you sure none of the suspension is way over tightened where maybe it doesnt want to pivot freely?
Old Mar 30, 2016 | 11:58 PM
Hoserbenzo's Avatar
I think maybe I installed the camber too tight? I'll keep it in the garage till next week when I get a chance to take off the rear wheels. Plus I just got my touch up paint. Going to work on that while I'm not driving it.
Old Mar 31, 2016 | 08:50 AM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
I'm confused. You added the camber kit to reduce negative camber but you're running a stock suspension? The stock suspension is fully capable of adjusting to the neg 1.8 degrees of rear camber, and neg .7 degrees of front camber and doesn't need a camber kit. Lowering the car will only stiffen the suspension.
Old Mar 31, 2016 | 09:57 AM
Hoserbenzo's Avatar
I'm running stock with 19" wheels. 265x30r19. I had to add the kit. It was eating up my tires.
Old Mar 31, 2016 | 02:59 PM
gixxerboy's Avatar
honestly dont know, its a strange thing you are have happen, just throwing out ideas, doing what you did shouldnt effect ride quality
Old Apr 1, 2016 | 12:39 AM
Hoserbenzo's Avatar
Thanks for all the ideas. I'll pull the wheels and check everything next week. Hopefully it's just that I'm so used to driving my truck.
Old Apr 6, 2016 | 10:23 AM
Hoserbenzo's Avatar
After driving my car for a while, I had come to realize that because I replaced my wife's tires on her BMW from runflats to conti's her ride is much softer than my Benz. That's because of my 19" wheels. Lol. Getting old sucks.
