side mirror turn signal and antenna on a 2004 clk500 convertible
Old Apr 11, 2016 | 11:11 PM
sziel99's Avatar
2004 CLK-500 cab, 2012 Toyota Camry, 2007 Honda Shadow 750, 2004 Honda Reflex 250
Hi everyone, I am new to a 2004 ckl500 convertible and:
1.Dash says the turn signal in the passenger side mirror doesn't work but the mirror moves like it is supposed to. Do you know what I need to fix it?
2.FM radio doesn't tune in and the key fobs don't lock or unlock the doors (they do have fresh batteries) although I can start the car by pushing the top of the gear selector. Does this sound like an antenna problem? And I found the antenna amplifier in the trunk, but it is hard to get at. I need to check fuses as well
Any help would be appreciated, I am trying to fix some of these minor-ish issues myself to try and save some dollars.
Thanks for any help you can provide
Old Apr 11, 2016 | 11:33 PM
Yidney's Avatar
2008 CLK550 Cab
Not sure what you are trying to say about the mirror moving. What does it moving have to do withe turn signal bulb not working? You need a bulb.
Old Apr 11, 2016 | 11:42 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
For FM reception and key fob RCL functions, check fuse #8 on the rear SAM (in the trunk). If it's blown, try replacing it. If it blows again, you likely have a dead ATA alarm siren. That siren is located under the fender shroud, behind the front passenger wheel. It's a "not uncommon" failure. Te Siren has a rechargeable backup battery that eventually dies and leaks and kills the siren. And in areas where you have a lot of snow and ice where salt is used, it can deteriorate the siren.
Old May 1, 2016 | 10:22 PM
sziel99's Avatar
yidney, thanks but wasn't the bulb, wires had come off the circuit board. I got a mirror from ebay and replaced the whole thing for $100 and now it is perfect.
Rodney/Rudeney, you really know your stuff. Before I read your post I went looking for bad fuses and you are on the money my friend, it was fuse number 8 in the trunk. All is well now, thanks for response. I am really having fun with this car and I am sure there will be more things i'll ask about as I get into it more. Thanks again!
