SOME ONE PLEASE HELP ME :wall: (PLEASE)
AFTER GETTING THE CODE FOR THE CPS
I REPLACED THE CRANK SHAFT POSSITION SENSOR
AND IT WAS A ***** TO REPLACE
AFTER THAT I CLEARED THE CODE . after i took my car for a drive everything was fine untill i parked it for 10 minutes and it turned of by its self . then i try to start it it just cranks ! so i waited and it finalley started . then i get the same code again after i just replaced it!
what can be the problem? also when i tuch my hood its very very hot. the engine warms up fast is that normal ?
but if any one ever had this problem please help! id verry much appreciate it. another symptom i have is car sometimes accelerates by its self on park or rpm might go up n down wiggling .
Just curious, what code are you getting? What are you using to read the codes?
also i think the heating is fine. but what im worried about is why the car turns of by its self ater 10 min in park.
Here's the other thread on this car. It's FLOOD DAMAGED. Electrical issues? Not really a big surprise given the flood damage.
How many boxes full of computers and electrical connectors are there in these? A couple dozen? You could spend the rest of your life chasing gremlins in a flood damaged car and still not get it right.
after replacing the crank shaft sensor . car was running fine . after a few i get these 2 error codes p0600 and p0120
but i replaced it with a genuine bosch and it was perfect for a few wtf man
im stuck with the car now i might have messed up for buying it . but it did not show any sign of flood damage other than the front sam module but thats because it had no cover for the fuse box
and also do you know anything about p0120 throttle/pedal position switch a circuit and p0600 serial communication link ? i got these two errors after replacing the crank shaft position sensor
but thanks for all your help i really appreciate it.
Now i just need to figure out these codes and then i will take it to mechanic
