wipers only work if car is moving forward
Old May 28, 2016 | 01:42 PM
sziel99's Avatar
2004 CLK-500 cab, 2012 Toyota Camry, 2007 Honda Shadow 750, 2004 Honda Reflex 250
wipers only work if car is moving forward any one dealt with that?
Old May 28, 2016 | 09:52 PM
sziel99's Avatar
All wiper speeds including intermittent work in D but not if the car is sending still, only if in forward motion. Don't go on at all in P or N
It's yet another quirk I have discovered.
Old May 29, 2016 | 10:17 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't know of any connection between gear position and the wipers. There are some other things, though, that will stop the wipers. The hood being opened (or registering as open) is one. Maybe it's possible that the hood latch sensor is broken just enough so then when still, it registers as open, but forward movement closes it? It's located in the left (USA-driver's) side hood latch.
Old May 30, 2016 | 06:35 PM
JimVonBaden's Avatar
2005 CLK500
Mine seems to not work when standing still on auto, but if I switch to low or high speed they work standing still. My 2016 Audi Q5 does the same thing. It is a bit annoying.
Old May 30, 2016 | 10:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Jim, your CLK500 should have a rain sensor. If for some reason it malfunctions, such as the wiring harness coming unplugged there behind the rear view mirror, it reverts to "intermittent" mode which is directly tied to vehicle speed. I wonder if that's what happened on yours?
Old May 30, 2016 | 11:34 PM
2005 CLK500
The rain sensor works fine, so long as I am moving. I can leave the wipers on and they will not move sitting still, or moving, when dry, but will come on when moving and raining.
Old May 31, 2016 | 09:20 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
So the sensor works - they wipe according to the amount of rain on the glass?
Old May 31, 2016 | 11:52 PM
2005 CLK500
Yes, so long as I am moving. Otherwise, the wipers do not move until I put them into the next higher setting.
Old Jun 1, 2016 | 11:55 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, I'm stumped!
Old Jun 2, 2016 | 02:31 PM
ambit's Avatar
09 CLK550
I've noticed the wipers will not auto-activate if the driver-side door is open (in Park)
I think the car is trying to prevent the door from being splashed. If you change the wiper speed up to 'high' it will go. But not on Auto or low.
If you close the door, it activates immediately.
Old Jun 2, 2016 | 03:05 PM
screw991le's Avatar
2010 E63 AMG
Mine go on the second I start the car. In any gear.
Old Jun 2, 2016 | 04:35 PM
sailorben's Avatar
CLK W209
Yeah with the ignition on, mine go as soon as the door is closed. Doesn't need to be moving in either of the CLKs I've had.
Old Jun 2, 2016 | 08:26 PM
Hoserbenzo's Avatar
08 CLK 350 sport, 11 BMW 328i, 99 Dodge Ram 1500 4x4, 06 Suzuki DRZ400SM
Maybe it's connected to your wheels. It only moves when your wheels move. Lol. Sorry I'm stumped too.
Old Jun 2, 2016 | 11:30 PM
ambit's Avatar
09 CLK550
You might be on to something..
if the two spurving bearings were in a direct line with the panametric fan the wipers might work
Old Jun 7, 2016 | 10:36 AM
sziel99's Avatar
Just following up on this, and problem solved for now. I was driving and my wipers were functioning, and continued to function when I put the car in neutral but then when I came to a stop at a traffic light they stopped. I think it was tied to the "your hood is open sensor". I would get that red warning on and off, although I had the wipers going when this warning would come up on the dash and they would keep working. Anyhow....I don't know if the hood sensor was seated properly or what, and I couldn't really tell if there was anything wrong, but I kind of jiggled it around a bit and reached underneath to push it upward and my wipers now function even when the car is standing still!! I also haven't gotten the "your hood is open" warning ever since the jiggle. I am now at peace with this car (purchased at the beginning of April 2016)....until the next thing.
Old Jun 7, 2016 | 11:42 AM
TechSuperstar's Avatar
15' CLS400
I've always had the same issue since I've own my car. As far as I can tell all sensors are working fine but if I stop for too long the wipers stop going until I start moving again. This only pertains to the 'autosensing' position. The only thing I can come up with is a bug in their autosensing software that takes speed in consideration and when speed is 0 it screws up ( / or * by 0 = ?) ... anyway, I've gotten used to it.
Old Jun 7, 2016 | 11:52 AM
2005 CLK500
Sounds just like mine.
Old Jun 8, 2016 | 09:24 AM
DanielFD's Avatar
2007 BMW 550i
My c230 and Clk320 both would slow down when i'm not moving and completely stop if i'm in anything other then D (maybe R, cant remember) in automatic mode.
Old Apr 12, 2022 | 06:29 PM
benzo021's Avatar
2006 Mercedes Benz C280 4MATIC
I finally figured it out! For me my hood sensor was always on my dash which I didn’t pay much attention to at first but turns out it is the reason why your wipers won’t work while parked. If you push down on the latch that has the sensor while the hood is up it should #1 fix the sensor issue and #2 it will give you the ability to use your wipers while parked. This is what worked for me.
