hydrolic oil problem
Old Jul 3, 2016 | 04:48 PM
Mansour's Avatar
clk 320 2005
Hello guys !
I have my mercedes clk 320 (2005) for 3 weeks now suddenly the hydrolic oul tank is draining without even using the cover ... not opening or closing it .... i filled it up twice and still after one day of filling it i checked it out and it was empty ! (Ddnt open the cover during that day after filling the tank ) any idea ?!!
Thank you in advance
Old Jul 3, 2016 | 05:48 PM
Yidney's Avatar
2008 CLK550 Cab
Yes. You have a major leak. Either a cylinder has totally failed, your reservoir has a leak, or the place in the trunk where all the lines join is leaking, your pump is leaking, or you burst a line. Since you have not used the top, the first place to check is behind the panel on the left in the trunk. If you are able to do it yourself then there is a lot of help on here. If you are not a person who does things like this yourself, you will need to take it somewhere. Just know that none of these parts are cheap if you have to buy new from a dealer. Labor is a lot too. Much better if you can do it yourself.
Old Jul 3, 2016 | 08:58 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
Go to a good indy mechanic and have him order from these guys. It will save you a fortune.
http://www.tophydraulicsinc.com/en/24-w209-clk
