Vibrating V-belt Normal? (Video)
Old Nov 22, 2016 | 09:27 AM
Reanimation's Avatar
270 cdi w209
Vibrating V-belt FIXED (Video)
So it's been like this since I got the car and after fitting new belt and tensioner. Had a look at my neighbors 270 s-class and his belt had no vibration at idle. So whats wrong.
Old Nov 22, 2016 | 06:02 PM
91ser's Avatar
2003 CLK500, 2003 CLK55, 2008 CLK550
Wow, that isnt normal!!
Did you replace the tensioner or the guide? There is one that is just a free floating pulley that also goes out, but it is not the tensioner.
Can you take the belt off and manually spin each component to see if any has inconsistent resistance? (ok, ok, dont try to spin the crank pulley)
Is there anything caught in the grooves of any of the pulleys causing it to jump?
Old Nov 22, 2016 | 06:03 PM
91ser's Avatar
Also, how much play is there in the belt when the car is not running? How much deflection does the belt have? It shouldn't have more than 1/2" or less each direction of play.
Old Nov 23, 2016 | 09:03 AM
270 cdi w209
I replaced the tensioner with pulley(febi), deflection pulley(febi) and waterpump(febi) along with a new Continental V-belt. I did check the resistance and condition of the components before, Ive just been out and taken the belt off to check again and cant find anything wrong. I started it up and it was nice and smooth for maybe 15 seconds then it changes abruptly. The deflection seems fine not to tight or loose. Could anyone reading please check theirs.
Old Nov 23, 2016 | 09:38 AM
Yidney's Avatar
2008 CLK550 Cab
Not many people here will have that same engine to check, but I have just as long a run on my belt and it does not do that. If the tension is good, then I suspect one of two things - first, although the pulleys you replaced may run smooth, one may not be perfectly round. It may be either slightly oval, or it may be round, but not running on center. Or second, the belt has some heavy spot or other imperfection in it.
Old Nov 23, 2016 | 10:38 AM
270 cdi w209
Appreciate the input, I might as well try a new belt and see what happens.
Old Nov 23, 2016 | 10:55 AM
Paulmurphy's Avatar
Cl 500 216
Alternator freewheeling pulley could be seized
it should turn free one way and turn the alternator the other way it takes out vibration in the belt
Old Nov 23, 2016 | 02:13 PM
sailorben's Avatar
CLK W209
If I recall correctly, once on my 270, I remember being able to fit the belt on in two ways. One way gave me too much slack. I could do the same on my 220 also. Made that mistake of not taking a photo of the belt path. Not again...
Old Nov 23, 2016 | 02:26 PM
270 cdi w209
The pully on the alternator felt fine, but I could be wrong. how do you know this?
Old Nov 23, 2016 | 02:55 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Why did you replace the tensioner to begin with? Was the same issue there before you replaced the tensioner?
The tension on the belt is obviously incorrect. Check all pulleys again. Sometimes damage is not visible unless you completely remove the pulley.
Seeing how the problem starts after 15 seconds or so, it's probably a pulley that's not visibly damaged or whatever was installed is incorrect or the belt is stretched etc etc.
Old Nov 25, 2016 | 02:35 PM
270 cdi w209
Well I think its the Alternator Because the more I use the electrics the vibrations get worst then settles down again.
Old Nov 25, 2016 | 04:29 PM
Paulmurphy's Avatar
Cl 500 216
To check remove the belt hold alternator pulley and turn clockwise it should feel heavy,
Turn pulley anticlockwise it should feel very light almost no feel at all, if it is heavy both ways one way bearing is seized. That's assuming that 270 is a diesel, video sound like it.
Old Nov 26, 2016 | 05:17 AM
270 cdi w209
Thanks, it goes tight in both directions so that's the problem, new pulley its is.
Old Nov 26, 2016 | 06:41 PM
Paulmurphy's Avatar
Cl 500 216
It can be bought separate and fitted without removal of alternator, but that requires a special tool.
Old Nov 27, 2016 | 12:43 PM
270 cdi w209
Yeah thanks dude I've ordered a new pulley and tool kit, fingers crossed it gets my engine running sweet.
Old Nov 30, 2016 | 11:52 AM
270 cdi w209
Fixed, New alternator pulley and the belt is smooth.
Old Nov 30, 2016 | 01:08 PM
Paulmurphy's Avatar
Cl 500 216
Nice one, super smooth now
Old Dec 1, 2016 | 06:59 AM
ALFAitalia's Avatar
Alfa 159
When I had a similar wobble on another car it was not the tensioner or any pulleys...it was the cheap pattern belt which over time has softened a lot more in one part than another....new belt sorted it. Glad you sorted it OP.
