Cap on Coolant Expansion Reservoir is Stuck
Old Dec 14, 2016 | 12:14 AM
SFCabs's Avatar
2008 GL320, 2008 CLK 350 Cab, 2004 CLK 320 Cab, 2010 BMW Z4
The cap on my coolant expansion tank is stuck (W209 M272 Engine). It doesn't budge even a tiny bit when I try to open it. If I try closing it more, it does have some give.
Has anyone else had this happen? I'm worried I'm just going to end up breaking the tank by squeezing and turning too hard on the cap.
Old Dec 14, 2016 | 08:26 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
do you have an oil filter wrench?
Old Dec 16, 2016 | 05:58 AM
SFCabs's Avatar
Yes, will that safely get it off? I think there's a tab on the bottom of it and maybe it got misaligned or wedged aginst the stop?
Old Dec 16, 2016 | 08:04 AM
insame1's Avatar
I dont think you really have any other choice. Either you get it off or you break it. One way or another you're going to need access eventually.
Old Dec 16, 2016 | 08:42 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If it's that well stuck, it's probably time for a new cap, and maybe even a new tank. Both are prone to leaks with age. The gasket in the cap will leak, and the tank will leak at the overflow nipple or the seal between the top and bottom halves.
