CLK500 Refix !
Old Jan 7, 2017 | 02:13 AM
tw2's Avatar
tw2
I think it should. You will need the supercharger, injectors, fuel rails, all pulleys including crank pulley and all accessory pulleys. All belts as well. You will have to find a way to control the supercharger internal bypass valve and the clutch pulley. Then you have to get a voltage clamp if you are retaining the stock MAF sensor and try and tune around this (not easy), fuel pump and intercooling too. I would try and get the whole engine, transmission, ecu and loom instead.
Old Jan 7, 2017 | 02:38 AM
Alien-83's Avatar
UFO.!
his engine has 284K miles and some things are broken up front the intercooler is crushed, this sounds as a big project maybe later i do it but i will maybe purchase the supercharger its $100 its high mileage,it needs to be removed and the car is not clean !
Old Mar 4, 2019 | 07:17 PM
Alien-83's Avatar
UFO.!
Hi am back and have a question i do an oil change every year on the car but i don't drive it much last year i only drove it like 50miles and the year before that i didnt drive it at all today i started it for the first time since last year and the oil cap is funny color the oil has funny discoloration like brown black and the oil has a bit of white is it normal shod i change the oil again
Update i forgot to mention the garage gets very cold in winter no heat
Old Mar 4, 2019 | 09:28 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Oil can get acidic, so it should be changed every year, but that's not what has happened with yours. In this case, it's moisture, probably due to condensation. Some good spirited driving that gets the engine up to full operating temp will likely clear that up.
Old Mar 6, 2019 | 07:15 AM
42N8SON's Avatar
2006 CLK500 C209
^^^^^This. AKA "Italian Tune-up".
Old Mar 6, 2019 | 01:08 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yeah, I was going to say Italian Tune-Up, but I figured half the audience would not understand.
Old Mar 6, 2019 | 02:01 PM
  #32
42N8SON's Avatar
2006 CLK500 C209
Half? Given my age and the number of decades that have passes since I first heard that term, I would lower that estimate to about 10%!
That said, I find that a weekly "tune up" is still as good for the soul as it is for the 5.0L V-8's combustion.
Rodney, I'm a new Forum member and you have already taught me much about my CLK. Thanks for sharing your wealth of knowledge and experience.
Old Mar 6, 2019 | 08:34 PM
  #33
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I was trying to be nice. I get in trouble for Millennial-bashing.
I try to get my car out on the freeway for some good exercise at least once a week, but it hasn't been happening a lot lately because of all the rain.
You are welcome! Trust me - I learn a lot, too. It's a fun hobby.
Old Mar 7, 2019 | 12:40 PM
  #34
Alien-83's Avatar
UFO.!
Rudeney i was thing about that could just be from sitting and when i start driving it will clear up
Old Mar 7, 2019 | 12:54 PM
  #35
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You know what they say..."Sitting is the new smoking!" I guess it's true for car engines, too.
